Springs on Dauphine Drums
Results 1 to 7 of 7
  • 1 Post By Frans
Thread: Springs on Dauphine Drums
    Jan 2013
    Geelong
    515
    Default Springs on Dauphine Drums
    I've started on my project! I fixed a flat tyre using the Fergie as a bead breaker: those skinny front tyres & that big heavy lump of a Vanguard motor worked a treat. I guess that brands me as an old geezer because I know how to use tyre levers & a rubber mallet.
    Can someone tell my why there are springs around the Dauphine's brake drums? Yeah, yeah, I'm Renault Virgin but we all have to start somewhere.
    1949 Citroen Big 6
    1955 MGA1500
    1970 Peugeot 404 Utility (Resto project)
    1962 Renault Dauphine Gordini (Resto project)
    1950 Grey Fergie Tractor
    Feb 2012
    Vista SA
    986
    I always thought it was for extra heat dissapation. Be interesting to see what others come up with.
    phil
    Jan 2013
    Geelong
    515
    Thnx Phil, I'm glad to see I'm not the only insomniac in the country.
    So the Italians use fins & the French use springs? With lateral thinking of that order no wonder they came up with the 2CV
    1949 Citroen Big 6
    1955 MGA1500
    1000+ Posts Frans's Avatar
    Auckland
    1,500
    It is a resonance damper. Basically the same as the block on the R8 stabilizer bar and the irregular pattern on tyres.
    Frans
    Wildebeest likes this.
    Boonah Qld
    2,537
    I am not that experienced with Renault drums on earlier cars but I haven't experienced any squeal or noticeable resonance as such but I tend to agree with both points of view. I think it does both, reduces the possibility of resonance as well as aids in cooling. Fence sitting.
    Fellow Frogger! bingham driver's Avatar
    Jan 2011
    Myers Flat
    182
    Spot on Frans, & resonance results in us hearing squeal. Works on the same principal as when you cut steel in a vise with a hacksaw & it squeals, but if you hold it with your hand or cut closer to the vice jaws it doesn't.
    Once I thought I was wrong but, I was mistaken
    Jan 2013
    Geelong
    515
    Ah! Perfectly reasonable & most inventive. I'm impressed with quite a few such finesses on the vehicle. e.g. the nifty "hairpin" spring that holds the engine lid up!
    1949 Citroen Big 6
    1955 MGA1500
