1962 Dauphine Gordini Project
Results 1 to 8 of 8
Like Tree3Likes
  • 1 Post By geodon
  • 1 Post By geckoeng
  • 1 Post By geodon
Thread: 1962 Dauphine Gordini Project
    Jan 2013
    Geelong
    514
    Default 1962 Dauphine Gordini Project
    1962 Dauphine Gordini Project-img_0538.jpg1962 Dauphine Gordini Project-img_0539.jpg1962 Dauphine Gordini Project-img_0546.jpg1962 Dauphine Gordini Project-img_0542.jpg1962 Dauphine Gordini Project-img_0540-copy.jpg1962 Dauphine Gordini Project-img_0541-copy.jpg1962 Dauphine Gordini Project-img_0543.jpg1962 Dauphine Gordini Project-img_0544.jpg1962 Dauphine Gordini Project-img_0545.jpg1962 Dauphine Gordini Project-img_0547.jpg1962 Dauphine Gordini Project-img_0548.jpg
    Greetings to the Renault Cognoscenti!
    My 1st post here.
    Behold my next project! After that lump of a Land Rover I did last, my dodgy back will appreciate something substantially lighter.
    This car has done only 40K miles. In 1984 in Tasmania it got a significant hit passenger side front & has been off the road since with the prev owner/s accruing a big haul of bits inc all I need to repair it. The interior is amazing right down the cream coloured floor matting. (WTF were they thinking??) The steering wheel is sad but I have another but in black/white.
    My plan is to renovate the hydraulics then get the motor running & drive it around our paddocks (don't stress they're quite smooth) to assess it's mech cond.
    Then once mobile I can get on & off a trailer easily & off to the body shop to get it stretched back into shape- the passenger bonnet mounts are ~ 50mm behind t'other side. The eagle-eyed may have notice the weird camber on the passenger front wheel. It looks like the stub axle is bent. I have 2 others but they are for disc brakes. Can I just swap the drum brake hub over?
    Once straight, I'll start to prep for a sympathetic re-spray. It has a real early 60's patina which I think is worth preserving and which would be lost in a full nut & bolt resto.
    An important question: source of spares? I found this place:
    Renault
    Anything better around?
    Caio!
    George
    1949 Citroen Big 6
    1955 MGA1500
    1970 Peugeot 404 Utility (Resto project)
    1962 Renault Dauphine Gordini (Resto project)
    1950 Grey Fergie Tractor
    Ipswich, Queensland.
    1,898
    I don't know if these are any better, but I have bought a fair quantity of parts with all of them with good results.
    Melun Retro Passion, Neo Retro, and Mecaparts, all in France.
    My wife has an early Dauphine G in nice condition. Her father rebuilt the motor last year, and it is a cheerful little car, albeit a little slow on big hills. The straight cut non synchro first gear sounds like grinding rocks on all of them as best I can tell.
    '56 Renault 750 (16TS Power)
    '62 Renault Dauphine Gordini
    02 and 03 Renault Clios 1.4L
    Simon's Avatar
    6,172
    Quote Originally Posted by geodon View Post
    Are the spare stub axles for a ball joint front end (R8/10) or a king pin front end (as originally fitted to the Dauphine G)? They don't interchange.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    Jan 2013
    Geelong
    514
    Thnx Simon. I was TOLD by the PO that they are from a Dauphine that was disc braked ex-factory- ex South Africa??
    I'm in the sticks ATM but will photograph them & post.
    I had a quick look & they looked the same (i.e. didn't have ball joints) except for the part that rotates.
    BTW congrats on owning the BEST of the VW beetles. That 1300 motor was a beauty. Lengthening the stroke was just what that wheezy 1200 preceding it needed. No wonder the Formula Vee's loved 'em!
    1949 Citroen Big 6
    1955 MGA1500
    Jan 2013
    Geelong
    514
    Ah yes! A reviewer, who was obviously very unkind, once claimed the best way to measure a Dauphine's acceleration was with a calender.
    27of85 likes this.
    1949 Citroen Big 6
    1955 MGA1500
    1000+ Posts geckoeng's Avatar
    Perth, WA
    1,663
    "geodon",
    The reviewer was American, and what do Americans know about cars ???? They can normally only go in straight lines or roundy-roundy. And take one hell of a lot of work to go around corners and stop quickly.
    Ray
    geodon likes this.
    Ray geckoeng
    Think Old, But Run Modern !!
    Jan 2013
    Geelong
    514
    1962 Dauphine Gordini Project-img_0549.jpg1962 Dauphine Gordini Project-img_0550.jpg1962 Dauphine Gordini Project-img_0551.jpg1962 Dauphine Gordini Project-img_0552.jpg
    Simon!
    It looks like I'm in luck!
    If you look you can see the bolt pattern to take a drum brake backing plate.
    I won't be certain until I try to put the hub on but it's promising.
    Of course I'm assuming the wishbones aren't bent :-)
    1949 Citroen Big 6
    1955 MGA1500
    Jan 2013
    Geelong
    514
    Default It's Alive!
    1962 Dauphine Gordini Project-img_0555.jpg1962 Dauphine Gordini Project-img_0558.jpg1962 Dauphine Gordini Project-img_0560.jpg1962 Dauphine Gordini Project-img_0561.jpg
    I got it going. Considering it was last reg 1984 it took very little- a good omen?? Using a gravity powered interim fuel supply, I pumped out the tank, the contents of which were very interesting.
    Heater hoses perished so I put in a bypass. Rad hoses drip but will do for testing etc.
    The float needle valve was stuck open do I took off the top (Solex 28PIBT?) to fix it & promptly cross-threaded the hot air inlet. Merde! Does anyone know what that thread is so I can clean it up with a tap? I was glad to see a fair dinkum auto choke- the VW ones used a heat sensitive spring that got hot with time & had nothing to do with engine temp. In hot weather, it stayed on unnecessarily & if you turned on the ign & didn't start up, the choke turned off! Most of the time I adjusted them to "no choke" & relied on the accelerator pumps to prime it- a la early 356A Porsches.
    I still have no hydraulics but after tightening up the handbrake & clutch adjustments I felt confident enough to try it out in the big paddock. 1st gear was a bit noisy. Normal or do I have a problem? 2nd is a ripper- ! 3rd seems long legged & the paddock was too small for 4th. Some lovely clonking noises from the front ends but overall it was good. Instruments & idiot lights all worked good.
    I probably should do a compression wet/dry test. What sort of psi could I expect?
    I can now trailer it easily and so the next step is to consult the alignment specialists to find out why the front wheels are cross-eyed. It would be crazy to start sandblasting etc until I check for bent bits.
    J-man likes this.
    1949 Citroen Big 6
    1955 MGA1500
