fuego driveshaft nut torque
Results 1 to 13 of 13
Like Tree2Likes
  • 1 Post By mistareno
Thread: fuego driveshaft nut torque
    8,395
    Default fuego driveshaft nut torque
    Does anyone know the spec on torquing up the fuego driveshaft?
    Cant seem to find my haynes book of lies anywhere and the front left driveshaft nut does not want to stay tightened up with what torque it has been getting. (which is a hugely scientific unit of..... decent effort on a 2 foot breaker bar).
    Cheers, Jo
    1000+ Posts Haakon's Avatar
    May 2002
    canberra...
    8,747
    I usually apply a torque setting of me standing on breaker bar with the trolley handle as a 3 foot extension.
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,017
    Cheers, Jo
    185 Lb ft or 250 Nm which ever you prefer.
    Is the nylon in the nut stuffed Jo? you are only suppose to use the nyloc nuts once. But having said that I have had no problems re-using them
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    Check the splines for damage. If the have play, they will loosen any nut.
    8,395
    Quote Originally Posted by mistareno View Post
    Thanks for the replies, guys.
    You might be onto something there, mistareno.
    Locktight high strength and about the right amount of force is not holding the nut on.
    Jo
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,017
    You would be able to feel play if the spines are worn.
    Also if the spines are worn you would probably be able to push the shaft into the hub by hand, without using the shaft installation tool.
    Regards Col
    1973 Alpine A110
    8,395
    Wow, thats a worry..... never hear of such a tool and always pushed them in by hand.
    Jo
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    Jo
    Me too
    Are you sure the thread isnt bottoming out before it pulls the shaft tight? They do have a pretty thick washer on them usually. Has that been replaced with a thinner one somewhere down the track?
    jo proffi likes this.
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,017
    Jo
    Hi Jo
    Heres the said tools, the smaller one is a factory one for R12/15/16/17 drive shafts and the larger is a home made one for Fuego/R25/Laguna.
    You just screw the tool onto the end of the drive shaft through the hub and use the nut to pull the drive shaft into the hub.
    Attached Thumbnails Attached Thumbnails fuego driveshaft nut torque-img_2705.jpg   fuego driveshaft nut torque-img_2706.jpg
    Regards Col
    1973 Alpine A110
    8,395
    Me too
    No, not sure but will check it now that you mention it.
    Col, thanks for the immage.
    When/if I ever have issues pushing a shft though I'll know what tool to make up.
    Jo
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    Cool. Then I can borrow it.
    Kenfuego likes this.
    Oct 2002
    Melbourne Victoria
    11,766
    If you have to reuse nylocs a little heat on the material will slightly melt the surface of the nylon and work just like a new one.
    1000+ Posts driven's Avatar
    Apr 2005
    1,424
    Me too
    The washer is actually a "High Tensile" washer
