R8/10 water pump base castings now available but without spigot for carby heater hose
Results 1 to 2 of 2
Like Tree2Likes
  • 2 Post By JohnW
Thread: R8/10 water pump base castings now available but without spigot for carby heater hose
    10,763
    Default R8/10 water pump base castings now available but without spigot for carby heater hose
    There was a post recently which I can't find, regarding newly available water pump bases. I have dug out mine, and found, as the post suggested, that the new castings do not have the spigot for the small rubber hose that takes coolant that warms the carburettor base and prevents icing.
    Here are a few photos of how to fix the problem. It's easy. Go to Repco and buy a brass spigot, 3/8", straight with a 1/8" BSP thread. Yes folk, we went metric in 1970. I really wonder sometimes.....
    Go to Toolmart or equivalent and buy a 1/8" BSP tap and then follow the photos, that is drill and tap the casting and screw in the spigot with some sealant. Carry 3/8" reinforced rubber hose so you can fix things on the road if you need to.
    John
    Attached Thumbnails Attached Thumbnails R8/10 water pump base castings now available but without spigot for carby heater hose-p9060721.jpg   R8/10 water pump base castings now available but without spigot for carby heater hose-p9060726.jpg   R8/10 water pump base castings now available but without spigot for carby heater hose-p9060728.jpg
    Sunroof and Wildebeest like this.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,020
    Nice easy conversion there John.
    I have done that trick when needing extra vacuum take offs in the manifold.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
