R17 front disc brake specs
    Fellow Frogger! IThompson's Avatar
    Sep 2011
    Bendigo / VIC
    226
    Default R17 front disc brake specs
    I am fitting r17 front disc brakes to my second R12. Before i assemble everything i want to check if the rotors still have life in them.
    I don't have an r17 repair manual.
    What are the disc wear tollerances?
    Ian
    Ipswich, Queensland.
    1,895
    Off the top of my rapidly thinning head, the original was 20mm thick, and minimum was 19mm, although most ventilated discs allow 1mm off each side. Often the figures are stamped into the outer edge of the disc.
    '56 Renault 750 (16TS Power)
    '62 Renault Dauphine Gordini
    '08 Renault Megane sedan
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,020
    Alan is right, its 19mm. Just looked it up in the factory manual
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Sep 2011
    Bendigo / VIC
    226
    Thanks i will measure them in the morning.
    There is signs of wear so i may need new
    Discs.
    Ian
    Dec 2010
    Blackburn Victoria
    474
    Hi Ian,
    I have a new pair of high quality German discs,
    may also have a pair of used - i will need to check thickness etc.
    May have a 1.4 head gasket if you are having trouble sourcing one.
    Let me know if interested.
    Cheers, Steve
    Quote Originally Posted by IThompson View Post
    Discs.
    Ian
