dauphine rear springs
Results 1 to 9 of 9
  • 1 Post By 4cvg
Thread: dauphine rear springs
    Feb 2005
    rosevale/tasmania
    2,745
    Default dauphine rear springs
    I'd appreciate it if some kind & knowledgeable frogger would tell me the wire diameter of a Dauphine rear spring (3-stud vehicles in case it makes a difference). My impression from somewhere is that the springs are thinner wire than R10 ones but I'd like firmer knowledge.
    Thanks in advance, Peter
    Simon's Avatar
    6,162
    From the MR 93 Dauphine manual:
    Pre-Aerostable rear spring - 12.75mm wire diameter, 99mm outside diameter, 278mm +- 1.5mm free length
    R1090 Aerostable rear spring - 11.1mm wire diameter, 99mm outside diameter, 337mm free length
    R1091 (Gordini) aerostable rear spring - 12.3mm wire diameter, 101mm outside diameter, 294mm free length
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    Feb 2005
    rosevale/tasmania
    2,745
    Ah! wonderful. Thank you Simon. (Why does it not surprise me that you had the answer?)
    cheers! Peter
    10,763
    That will make quite a range of spring rates. If I recall my advice from Phil in Q'ld, the torsional property is proportional to the fourth power of diameter. So the 12.75 mm spring would be 74% stiffer than the 11.1 mm spring. I found last year that a small change in front spring wire diameter on the 4CV made a huge difference.
    Of course, a good spring works would maybe have some other wire diameters in the range you want.
    Interesting.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    Citroėn CX Pallas 1980
    Feb 2005
    rosevale/tasmania
    2,745
    Interesting.
    To make my agenda apparent:
    As you know, I am an enthusiast for transverse leaf spring camber compensators on these vehicles. My 4CVG has standard R10 springs with one turn removed. This gives me 3-3.5° of -ve camber & very little residual travel in bump. The CC spring's function as an auxiliary spring in bump is a quite useful side benefit in this respect.
    Removing one turn increased the spring rate & thus rear roll stiffness. Not what I wanted but I've gained more from the lower CG & -ve than I've lost from changing the roll stiffness front-rear balance in the wrong direction for these cars.
    The R8 also has a CC but with standard R10 springs. Even with the shortest springs from my collection, it has only 1-1.5° -ve. As the CC is acting as an auxiliary spring, the rear isn't sagging into as much-ve as I'd like. I could go down the same path as the 4CVG & lop an R10 spring but I wanted to have more ground clearance on the R8 (my "daily driver") than I have on the very low 4CVG. I'd also like to lower the main spring's rate compared to the R10 as a little experiment.
    So, my thinking is to use the thinnest wire Dauphine ones & lop to standard R10 height. They should still have a lower rate giving me two advantages. First, the rear roll stiffness will be lower & second, they'll sag more into -ve (I'd like about 2.5°). Having the CC perform more of the "bump" springing function should, by lowering rear roll stiffness, improve the (already good) rear end behaviour in brisk "C"-road work without resorting to the greater -ve camber of the lower 4CVG.
    All good clean fun!
    So, if I can't scout up some 11.1 Aerostable Dauphine Normale springs here in the South Island of Australia, then I'll be trawling on A.F. for some from the North Island.
    cheers! Peter
    jaahn likes this.
    Feb 2005
    rosevale/tasmania
    2,745
    Hmm! no luck so far in down under Down Under. So, a general bulletin:
    Does anyone have (& be willing to sell me) a pair of these:
    I don't care how tired & sagged they are; indeed, for my purposes, I'd prefer them that way. Crucial is the wire diameter.
    cheers! Peter
    Feb 2005
    rosevale/tasmania
    2,745
    Problem solved.
    Thanks to Simon for providing the specs & to Hans for matching the specs to a set of springs he had & selling them to me.
    Another fine manifestation of the joys of Frogger fellowship!
    cheers! Peter
    Nov 2005
    Geraldton
    1,569
    Can do better...
    I have a pair of the aerostable bellows thingies that look to be in good nick.
    Yours for the asking.
    P
    In the Shed(s):
    In the Past:
    Feb 2005
    rosevale/tasmania
    2,745
    Can do better...
    P
    I appreciate the offer but my interest in the springs is connected with the rear of my R8, not a Dauphine (see above post). I don't have a use for the air bags & they're better kept for someone with a Dauphine or D-G with ones which are buggered.
    cheers! Peter
