What is this head off?
Results 1 to 19 of 19
  • 1 Post By Sunroof
Thread: What is this head off?
    Oct 2012
    600
    Default What is this head off?
    This was in the bottom of a box of parts I got with the first R10, what is it off and does anyone want it? The rocker gear is all there but very stiff, the rocker return springs may need replacing. There are no valves. There is some pitting on the bottom face where the cylinders are, the rest of the face looks ok.
    What is this head off?-img_20140816_150246.jpgWhat is this head off?-img_20140816_150302.jpgWhat is this head off?-img_20140816_150310.jpg
    monbulk
    648
    That looks to be head from the "Ventoux" series of motors.
    I would think that it is from a Dauphine.
    Seeing as you got it with an R10, I would assume that it is from a rear engined car too.
    However, on closer inspection there is a blanking plate at the rear/bulkhead end of the motor.
    It could also be from a Renault 4 of the first series in Australia, the one with the bread loaf grille.
    The casting numbers will identify it with certainty.
    All you need is someone more expert than myself!
    David
    It's how I roll...Brisbane
    33,162
    Well we can rule out a Fregate...
    Attached Thumbnails Attached Thumbnails What is this head off?-005-3-.jpg   What is this head off?-007-3-.jpg
    1000+ Posts J-man's Avatar
    Littlehampton, S.A.
    23,145
    My guess is Dauph too. It doesn't have the bonnet rod drilling that 4CV's have ...
    cheers,
    John
    1000+ Posts FIVEDOOR's Avatar
    Jun 2011
    Brisbane Qld
    20,330
    Every day is a good day
    33,162
    I do believe we are narrowing in on it...
    Boonah Qld
    2,532
    Dauphine Gordini and Floride
    Oct 2012
    600
    If the casting numbers help I'll take a look tomorrow and post them up.
    Sent from my C5503 using Tapatalk
    Apr 2011
    Melbourne, Australia
    175
    Hi,
    My guess is a Renault Dauphine Gordini head. The numbers on the head on my Renault Gordini motor are 256123-81 G for Gordini.
    Regards
    David
    Jun 2011
    Brisbane Qld
    20,330
    Check out post number 5 by Simon which explains difference between the early and later Dauphine G heads.
    Year of Dauphine Gordini
    Oct 2012
    600
    The casting number is 2561231_81 G. So I guess that makes it a Dauphine Gordini head.
    Simon's Avatar
    6,172
    The staggered manifold studs also confirm it as a Type 670-05 Dauphine Gordini head.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    Oct 2012
    600
    Free to a good home.
    Boonah Qld
    2,532
    As does the one remaining locating sleeve for the inlet manifold. Some manifolds had both staggered and non staggered locating holes. I don't know what the different ones were for. Perhaps when used as a spare part they could be used with both manifold types. Some Dauphine heads had the locating hole for the bonnet prop similar to that on the 750. Why? Further some Dauphine heads had a hole in the top for water to circulate to the radiator as they were fitted with earlier style water pumps like the 750. Also as I understand it, the early Dauphine G heads had inclined valves perhaps Simon could confirm this.
    Jun 2011
    Brisbane Qld
    20,330
    Content from Simons Post #5 from http://www.aussiefrogs.com/forum/new...treply&t=17326
    The very early (up to around oval plate number 26,000) R1091’s had a unique Gordini designed head with angled valves, and alloy rocker cover as opposed to the later Dauphine G head with vertical valves. This early motor had the designation 670-04 as opposed to the later type with the steel G rocker cover and vertical valve head 670-05 motor which was also used in the Floride. Both produce around the same horsepower of 40bhp, but my guess the change was because the 670-05 motor would be cheaper to make using the existing normal Dauphine head castings.
    Those early 1091’s would be quite rare with elaborate Dauphine Gordini badging and non vented wheels, overall a plainer car than the later Dauphine G in terms of trim though. I’ve never seen one in the flesh, but have heard of the odd alloy rocker cover coming up for sale, and there are pics of cars in contemporary magazines and adverts with AUS rego plates so were sold in Australia. Being fully imported into Australia they were quite expensive at the time which probably explains their rarity, as well as their very short time on the market between 1960 and 1961. The later Dauphine G’s with the 670-05 motor were introduced in Australia in early 1961 and being assembled in Australia were a fair bit cheaper to buy at the time than the earlier model.
    Ipswich, Queensland.
    1,898
    I would very much like the head for a friend that has just bought a road going 4CV, only that it needs a bit more sting on the hills. The thought is to build up an 850, do the usual hot up mods, make up some extractors and fit a pair of SUs probably. I have sent you a PM.
    Thanks.
    '56 Renault 750 (16TS Power)
    '62 Renault Dauphine Gordini
    ‘02 and ‘03 Renault Clios 1.4L
    Boonah Qld
    2,532
    Quote Originally Posted by FIVEDOOR View Post
    Thanks for that, that information wasn't what I got when I clicked on the link.
    FIVEDOOR likes this.
    Boonah Qld
    2,532
    I have been led to believe that the engine with the head with the inclined valves had a standard Dauphine cam. Gordini was asked not to change the cam and so changed the head by inclining the valves and there by creating a better flowing head. If that is so then I imagine that if an engine had the head with inclined valves as well as the G cam it would be even better.
    Boonah Qld
    2,532
    This photo shows the dimple for the 4CV bonnet prop? The head is 2561231 there is no G but the engine is 670-05 *94080* and comes from a Floride I would believe it is original as it has low K's.
    This photo shows the dual stud positions for both versions of manifold. The head has the No. 2561231-81G engine number 670-05 143850. No idea what car it came from but I believe it came from a Dauphine G. Not sure if the head is original. The engine in my 4CV also has a Dauphine G head that has both stud patterns for the manifold.
