R12/17 disc rear end differences
Results 1 to 12 of 12
Like Tree3Likes
  • 1 Post By Jensen
  • 1 Post By angru
  • 1 Post By Simon
Thread: R12/17 disc rear end differences
    Fellow Frogger! Jensen's Avatar
    377
    Default R12/17 disc rear end differences
    Does anyone know if the rear beam itself was a unique part for 12/17s with disc rear ends or is it the same as the rear beam on cars with drums?
    Basically want to know if you had the discs/hubs and the calliper brackets, could these be bolted on to a rear beam that originally had drums?
    IThompson likes this.
    2002 Monaco Blue Renaultsport Clio 172
    1975 R1317 Renault 17 Gordini
    8,899
    Nope. Different beam ends.
    Not to say it could not be done with some surgery, but it's not as straightforward as bolting on the disc end tidbits.
    ACHTUNG ALLES LOOKENPEEPERS
    Dec 2010
    406
    What?? I'm sure they're the same.... Maybe it's just the wagon that's the same... I've swapped them over, only difference I could see was that the disc brake one had brackets for the flexible brake pipes to sit in.
    David Cavanagh likes this.
    8,899
    Different back plates riveted (welded?) to the beam ends.
    Fellow Frogger! Only19's Avatar
    760
    The backing plates are bolted ... I remember this as too many hand-brake turns in my 12 wagon during motorkhanas wore the holes oval.
    Who needs brakes? They only slow you down ....
    Feb 2001
    Romsey, Victoria, Australia
    4,838
    Quote Originally Posted by angru View Post
    Agree, we've just welded the brackets on and used them without any problem.
    David Cavanagh
    03 9338 8191 or 03 93354008
    34 KING St
    AIRPORT WEST
    VIC 3042
    [email protected]
    377
    Great thanks everyone, my parts book had different numbers for the actual rear beam for disc and drum cars but sounds like it's just the hose brackets that differed.
    Nov 2005
    Geraldton
    1,572
    Ok, the next question is, what rotor, hub, bearings, calipers and bracket do you stick on it?
    How do you manage the handbrake attachment?
    P
    In the Shed(s):
    In the Past:
    377
    Rotors are easy, R12 fronts.
    Hubs and calliper brackets are tricky, they are from 12G/17TS/G.
    Callipers themselves I think are shared with Fiat 124 (somebody might be able to confirm).
    Handbrake cable and hoses from Mecaparts.
    Boonah Qld
    2,532
    The same callipers are also found on R20 diesels. Not much help as none came to Australia. I got a set from someone who got them from an R20 in New Caledonia. I mentioned to a brake repairer that they were rare and he also said to me that they had similar ones on either a Fiat or a Subaru.
    377
    Ok brains trust, a follow up question. Are the beams also the same between R12 sedan and R12 Wagon/R17?
    Reason I ask is I have a complete 17TL rear beam here ready for R8G's R12 sedan. Rather than ship the whole rear beam, can I just send the larger drums to bolt on to his sedan rear beam?
    Simon's Avatar
    6,172
    Quote Originally Posted by Jensen View Post
    In a nutshell, yes. However, is R8G's car a Virage? In which case, if the oval plate number is 7115 onwards, it may be fitted with the wider 18GTS rear beam, which also has different wheel bearings.
    JohnW likes this.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
