Fuel pump relay on Fuego Turbo
    Canberra ACT
    721
    Default Fuel pump relay on Fuego Turbo
    Hi all
    Does anyone know where the electric fuel pump relay is on a Fuego Turbo. The only relay that I thought was it was on the bulk head next to the ECU but it is labelled in the Haynes manual (page 263) as an ignition cut out relay. Schematic diagram shows the relay on page 266 called item 187 which is described on page 262 as "Speedometer relay (fuel pump)" but does not show exactly where it is!
    Canberra ACT
    721
    I think I have found it. Located at the bottom of the centre console on the inside and on the right hand side. See photos. If anyone has a parts manual that covers a Fuego Turbo, could you confirm. Part No is 7700 660 387.
    Simon's Avatar
    6,203
    Quote Originally Posted by bazzamac View Post
    In what is a bit of a rarity, the number on the part is an instant match to the one in the parts catalogue. It is confirmed that the part is a Fuego Turbo fuel pump relay.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    Canberra ACT
    721
    Thank you Simon.
