timing mark R8
Results 1 to 11 of 11
  • 1 Post By JohnW
Thread: timing mark R8
    Fellow Frogger! forzamacchi's Avatar
    Oct 2013
    Los Angeles, United States
    235
    Default timing mark R8
    Hey All.. I am attempting to check the timing on my R8 with a gun. I see the timing marks on the case, but I cannot see the mark on the pulley. What should I be looking for? A line? What kind of mark? Thanks! Ben
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    4,344
    Quote Originally Posted by forzamacchi View Post
    Hi Ben
    As these motors are similar to an R12 there should be a small nick in the crankshaft pulley.
    When you find this small nick fill it with tippex or white paint, makes it easier to see when timing motor.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Simon's Avatar
    6,203
    There are near Heinz 57 varieties of crankshaft pulleys for the various motors, depending on the era. Usually there is a mark on the periphery of the crankshaft (fanbelt) pulley, which can be either well or poorly defined, depending on who was in charge of marking pulleys on a particular day.
    Try lining up the distributor rotor to No. 1 cylinder (No. 1 is flywheel end on a Renault motor) then have a look on the periphery of the crankshaft pulley for a mark, the mark should be close to the TDC mark on the timing cover pulley. Once it has been spotted, apply a decent spot of paint to the mark and the one on the timing cover.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    11,306
    Imagine a hacksaw cut as deep as it is wide, on the engine side of the pulley vee. That's TDC. There are different alignment marks on the timing case, depending upon motor. But once you find it, and then get the engine to TDC mechanically - e.g. rod through spark plug hole, to use an old fashioned but effective method, all will become obvious.
    Good luck.
    markb2501 likes this.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    4,425
    With my r12 powered 10, I have to time it from underneath, so as others have said it does depend if you have std setup or modified. Simons suggestion of setting TDC THEN looking for marks (top and underneath) makes sense.
    KB
    It's how I roll...Brisbane
    33,986
    Isn't there a TDC mark on the flywheel visible through an aperture in the bellhousing...? It's a bit hard to get to but a mirror should help.
    Every day when I wake up I reach up in the darkness with my eyes shut and if I cannot feel anything that resembles a wooden lid I know it will be a good day. No lid today.
    4,425
    Quote Originally Posted by 59 Floride View Post
    On a Mini, yes.
    I don't think so on the r8, the marks are at the other end.
    KB
    33,986
    On a Mini, yes.
    I dunno about that, it would be worth checking, my R12/R10 mongrel Floride has these marks and I'm using a 10s bellhousing, there is a pointer mark on the bellhousing aperture and a deep groove on the flywheel at TDC.
    11,306
    I didn't know that. I'll dig out my spare R8/10 crankshaft and have a look.
    Oct 2013
    235
    Thanks Guys... I will do some sleuthing with your recommendations! I am installing a pertronix ignition and would like to check the timing when completed. Almost there!
    Boonah Qld
    2,637
    I always thought they were on the fan drive pulley and the timing cover. They most definitely are on my Floride S Sierra 688 motor.
