R10 Front wheel bearings and seal
Results 1 to 8 of 8
    127
    Default R10 Front wheel bearings and seal
    Hi All
    Trying to get an R10 RWC. I have got the discs from OS didn't think about bearings and seals.-Now seals and bearings are a challenge.
    I am in melbourne any suggestions on where to get these would be would be welcome.
    Rob
    Canberra ACT
    721
    TRy Caravelle Imports at North Box Hill ph 9890 9061
    127
    Thanks Bazzamac-but they can't help
    4,425
    If you have the old bearings and seals you could always try taking them into a CBC bearing shop or something similar. Otherwise you're back overseas buying them from one of the established suppliers like Mecaparts, melun retro etc.
    KB
    11,293
    Quote Originally Posted by robere View Post
    The R10 inner bearing is unique if I recall. I think it's a 30204 but a built in extension at its inner base. The outer is 30203, a pretty standard tapered roller, again from memory. They are usually in stock at Mecaparts or Melun Retro Passion - good opportunity to stock up and maximise the value of the postage. Set of door lock rubber seals? Set of door window seals? Some calliper seal kits?
    Otherwise, they appear on ebay sometimes as kits. Try ebay US and ebay France too. I always carry spares for my R8 but it is an early one with the same bearings as Dauphine and 4CV. I'd suggest you keep a spare set or two while you are about it.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    127
    Thanks John
    Rob
    668
    Hi Rob
    try Tanner at Southern Bearings PTY Ltd.33 Mollison St, Abbotsford VIC
    (03) 9429 1222.
    he should be able to help out.
    angelo
    127
    Thanks Angelo
    Robin
