Clutch Vibration/Shudder
Results 1 to 9 of 9
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    Default Clutch Vibration/Shudder
    Been having a clutch shudder in the Fuego that is a bit odd.
    It's an aftermarket clutch (Quinton-Hazell) that has been in for about a year.
    In that time it's always had a slight shudder when shifting down through the gears (ie under braking and going back to third or second at speed)
    It doesn't shudder at all when taking off or any other time.
    I don't know if it's got any worse, or I just notice it more, but I decided to pull the engine out and check the clutch. I expected to find a loose rivet or spring, but it all seems good. The flywheel seems ok too, with no overheat marks, but I'll get it machined just in case. There is no oil contamination.
    I notice that there is no bush/bearing in the crankshaft, but I don't recall there ever being one?
    Could the firmer engine mounts be responsible?
    I haven't removed the gearbox mount yet but it looks okay (if a little soft).
    Any other ideas?
    Is there supposed to be a spigot bush in a Fuego? Have I lost it somewhere along the way?
    The Haynes manual doesn't really shed any light on the matter...
    1000+ Posts Haakon's Avatar
    May 2002
    canberra...
    8,876
    Might be the springs still - a bit weak but still ok visually. I too would have expected to see something spring/rivet related...
    No spigot bush - input shaft supported by bearing in bell housing.
    I found a huge difference between Sasic and Valeo clutches for the Fuego - the Sasic one I did not enjoy at all. I'd expect QH to be good though (best aftermarket water pumps I found after trying a few not so good ones!).
    You've gone to all that bother now though - put a new Valeo in.
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    Yeah, I just don't want to fork out for a new clutch as it will probably only be in for a few months until the new motor is finished and then I might get something a bit stronger made up.
    I suppose it's handling a little more power than it's designed for, maybe the springs are on the soft side. Just strange that it's only on down change and not under load.
    Might pull the gearbox mount off.
    Oct 2002
    Melbourne Victoria
    12,625
    I think I have a good S/hand Valeo clutch sitting in the garage if you want to try same. I seem to have a vague recollection of some early Fuego gear boxes with the longer shaft and spigot bush setup. I'd have to trawl through some of the spares to confirm.
    The Valeo clutch was always softer in operation than some of the Australian "heavy duty" replacement clutches, and the reason I kept the Valeo clutch just in case!!
    In the MOT. J engine manual it mentions removing spigot roller type bearing "if fitted" and a quick check of the BV NG gearbox manuals two different extensions are shown (component 74) with and without spigot.
    Ken
    Fellow Frogger! Mungous's Avatar
    NZ
    335
    QH clutches are rubbish. After fitting two to customer cars and having both come back with shudder within months I tried one in my own car to see if the problem was the driver or the part.
    Mine started shuddering after about a week despite a refaced flywheel and gentle use, and I have sworn off those useless things forever.
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    Quote Originally Posted by Mungous View Post
    Cool. I thought it might just be the clutch. I've never had any clutch issues with any car I've owned so I think I'm pretty sympathetic to them.
    I'll whack a valeo in it.
    8,484
    Quote Originally Posted by mistareno View Post
    My fuego with super stiff engine/box mounts has a valeo clutch, and no vibrations to report after 20k km.
    Jo
    Fellow Frogger! Trading Estate's Avatar
    587
    Check that soft gearbox mount as well. First thing I always eliminate
    '04 Megane
    Gone but not forgotten
    '71 16 TS, '72 16 TL, '74 15TS,'82 20TS Series 2, '85 25 GTX. '49 L15,
    11,302
    That's disappointing, but good to know. Thanks for the heads up.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
