Renault 12 Indicator Issues
Results 1 to 9 of 9
    Tadpole R12GL's Avatar
    May 2013
    10
    Default Renault 12 Indicator Issues
    As our Peugeot was towed away this morning after the "Engine Fault - Repair Needed" and "Engine Temperature Fault - Stop The Vehicle" warnings appeared on screen, the 12 was called into service for a family dinner this evening.
    However, for some reason the right indicator on the 12 has now decided not to work when the headlights are turned on. Left side works fine.
    I'm assuming it's some sort of connection issue and wondered if anybody may have come across this before, or have any recommendations on how to trace the fault?
    Cheers, Corey
    1974 Renault 12 GL
    2012 Peugeot 208 Allure
    Simon's Avatar
    6,203
    So it is only if the headlights are on? And I'm guessing the front blinker is blinking fast, with no rear blinker, and no blinking light on the dash or clicking? Also, you have checked for loose globes?
    If so, it sounds like a rear earthing problem. (Also assuming it is also a pre-1976 12 (so pre 12XL/1.4/Virage), with the small tail lights) For the rear lights, the upper outer light unit retaining bolt also acts as an earth to the body. Remove the light unit (the cover over the wires slides to the side rather than being pulled off, also mark which wires go where before removing them from the spade terminals), by removing the three nuts securing the light unit to the body, then also remove the upper outer bolt from the light unit, under the nut you will find the brass earthing strip to the body, clean up the connection, replace the nut, then clean up where the light unit earths to the body. Also check that where the brass strip is riveted to the light unit to earth the individual globes, that the connections are clean and sound, (in unusual circumstances the brass strip can fracture). Replace the light unit, replace the wires and check to see if it now works.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    May 2013
    10
    Simon, that's correct. It's only when the headlights are on. I'll investigate further tomorrow with your recommendations. Thanks!
    It's a '74 GL, and I think you may know the car. Originally owned by a Mrs Rowe in Clearview SA. I've had it about 18 months but think you may have provided the previous owner with some of its history? It was in pretty good shape and we've also done quite a bit to tidy her up.
    Cheers, Corey
    1974 Renault 12 GL
    Fellow Frogger! IThompson's Avatar
    Sep 2011
    Bendigo / VIC
    226
    Corey,
    I have a R12 GL 75 i have a similar issue that i haven't investigated yet.
    The heater fan stops when the headlights are on.
    Ian
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,333
    Sounds like bad earth to me or dirty connections.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    11,295
    Yup, bad earth somewhere. Start with Simon's detailed (wow!) instructions.
    These things always sort out with systematic attention. Do one thing at a time and check whether there is an improvement or you'll never know what was wrong, and how to fix it next time, if there is a next time.
    Good luck.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,333
    The main earths are on the front left and right inner guards at the bottom right next to the radiator; at the rear lights; number plate light; interior light; door and boot switches; there are a couple of earths under the dash. Hope this helps a little
    Regards Col
    1973 Alpine A110
    May 2013
    10
    Thanks all!
    Unfortunately we can't get the tail light lense off - the head of the bottom screw is completely stripped but I'll attempt to gently drill this out on the weekend.
    We've also just realised that the tail light lenses are slightly different - the one on the right has a small chrome strip separating the indicator and brake / tail light whereas the left doesn't. Does anybody know which would be correct for this model (74 GL)?
    Cheers, Corey
    1974 Renault 12 GL
    Simon's Avatar
    6,203
    Quote Originally Posted by R12GL View Post
    The one with the separating chrome strip is a pattern part made by Yorka in Spain, the original is a Seima 609 (sans chrome) Made in France.
    Try just giving the RH upper nut retaining the tail light to the body inside the boot a loosen and spray with your fave contact cleaner, or CRC magic spray. The bolt is captive and retained with another nut in the tail light base so won't be lost within the light unit. If you are lucky, the poor earth may just be just the light unit connection to the body.
    1963 Renault R4 Van
    1964 Renault R4
