R8/10 type 330 transmission speedo
Results 1 to 22 of 22
    Jul 2013
    southampton Ontario Canada
    89
    Default R8/10 type 330 transmission speedo
    I have a R8 / R10 type 330 transmission that I need to change out the speedo drive gear because it is damaged ! Is there an easy way to get at the gear to change it ??? I have tried to pry out the plastic plug that allows to get at the drive but it seems tough to move so rather than break something I thought I would see if there is a easy trick to get it out .R8/10 type 330 transmission speedo-renault-330-transmisson-rebuild-speedo-gear.jpg
    My book does not deal with this and any suggestions would be appreciated.
    Manic GT
    Simon's Avatar
    6,203
    The plastic sleeve is usually held in place by the bolt that also secures the speedo cable. Once the bolt is removed, the sleeve generally falls out. Sometimes though previous people have glued the plastic sleeve in place (rather than replacing the o-ring or oil seal to minimise leaks), perhaps a bit of gentle persuasion on the end of the chewed gear will help to shift it.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    11,310
    Simon is right of course. There's a bolt head on the opposite side (outside) of the housing you have photographed. New and secondhand gears are available here and there, but be careful to count the number of teeth as there are many different sizes.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Jul 2013
    89
    I have the bolt out and was trying the gentle persuasion but I guess someone must have glued it in so a little more aggression may be needed .
    Thanks for the info I just didn't want to break something in case I have overlooked some small detail.
    Manic gt
    11,310
    Quote Originally Posted by manicgt View Post
    Manic gt
    Very wise too! At least, with the gear and sleeve, you will be able to find replacements. Let me know if you can't and I'll burrow into a few websites for you.
    Jul 2013
    89
    I got the sleeve out by using some heat but not before breaking the gear up using the greater persuasion tools .( large punch and hammer I figured the gear was no good any way )
    I will be needing a green speedo gear not sure if they were identified with the colour or number of teeth.
    My pinion gear has 8 teeth and the large ring has 33 teeth.
    Any help would be appreciated.
    Manic GT
    11,310
    Manic GT
    My advice is to retrieve the bits and count the teeth on the speedo drive pinion. There are about four different numbers of teeth.
    Simon's Avatar
    6,203
    If you can't find anything closer, I've got a new green 13 tooth drive gear, part number 08 30 050 300.
    1963 Renault R4 Van
    1964 Renault R4
    Jul 2013
    89
    Default 330 type transmission
    Thanks for the offer I will be checking around to see what I can find in my own parts first. I was just curious at this point how Renault identified the different speedo drives ??? Mine in this unit was green but is that always a 13 tooth drive ?? Will continue with my first trans rebuild to see what else I run across.
    Thanks for all the help and generous offer.
    Manic GT
    Los Angeles, CA USA
    1,955
    You should be able to introduce the correct gear to the casing which I think is the same. And do not feel bad. I had to butch one out too.
    Doing the Daffyduck dance via the AussieFrogs app.
    Simon's Avatar
    6,203
    It is generally the colour of the cog, especially in the same family of gearboxes, so a green cog in a 330 'box will be a 13 tooth cog. Though Renault don't specify a particular cog colour in the parts catalogue, just the number of teeth and the part number, so there could be exceptions depending on production batch that I've not seen.......
    1963 Renault R4 Van
    1964 Renault R4
    11,310
    Do you have any others Simon?? They do appear on ebay and the odd parts supplier from time to time. Definitely a precious item, not something you'd make up on the average home workshop bench!
    Gears and sleeves appear, for example, sometimes on Web Pieces Retro (www.web-pieces-retro.fr)
    Good luck.
    Simon's Avatar
    6,203
    There are a few others, the Renault 16 ones break the same colour rule, one being blue, the other purple, both being the same part. This particular green/13 one though has excellent provenance, coming from the personal collection of Jacques Thoridnet, it's gotta be worth a motza!
    I don't know about that. Given future improvements in scanning and 3D printing, it won't be too long until good quality reproductions can be created from home. Shops will sell the scanned dimensions, which can be printed at home on the. The only thing they won't have is the Jacques Thoridnet provenance.......
    1963 Renault R4 Van
    1964 Renault R4
    11,310
    You have a point there, but we'll have to wait a while. Right now, I have a little 3D scanning and printing project going, and the cost of printing remains horrendous, if done to a high standard anyway. I now have the 3D CAD files and the dilemma of printing what I want at far too high a cost, or waiting two years, by which time maybe the printing costs will have come down!
    That provenance is great, Simon!
    Simon's Avatar
    6,203
    That's right, at the moment it seems to be in a transition zone between the last of the NOS for oldies and relatively cheap and quality 3D printing. Though it didn't seem to take too long for photography to progress from state-of-the-art 0.8MP Mavicas (which I thought took horrible pics) till now when digital photography is quite passable. Then it will be a case of better plastic than classic for the ease of reproduction.
    I thought it sounded very impressive too. Though it seems from looking at the book Alpine Renault, the fabulous Berlinettes (ISBN 978-1-845844), page 163, he has become the forgotten man. Apparently even the Alpine afficionados don't know who he is....
    1963 Renault R4 Van
    1964 Renault R4
    11,310
    Re Jacques, that is a real shame, and a bit hard to understand.
    The 3D print quality is there now, and more materials are becoming available for "printing" items with. However, the prices are still sky-high because of printer cost and also the costs of the materials prepared for feeding into the printer etc.
    There are newly made speedo drive gears out there, as I've seen all metal ones on one of the French sites, but can't recall which. In the meantime, husband your stocks, if you have any at all!. The normal printing material seems to be ABS+ or something like that, which is ABS with an additive to make it conductive. I reckon that would be good enough for a speedo drive actually but the one-off might cost $500+ right now. Very interesting as this technology evolves and becomes accessible.
    Ove
    Ove is offline
    Germany
    69
    Does anybody know the correlation between the gearbox-types and colors of their cogs?
    I have found white, red, blue, green and black ones in my stock.
    Brisbane/Australia
    2,207
    I know this is an old thread and I don't wish to hijack this but it's the only thread that came up when I searched on speed drive gear, but my question is the R12 speedo drive gear held in the same way as the R10, i.e. interference fit?
    I know the R10 & R12 are at different ends and have different linkages but perhaps Regie Renault raided their parts bins when they brought out the R12 and didn't try to reinvent the wheel so has similar designs.
    I have an R12 parts list (PR1012) but I couldn't find a drawing or part number for the speedo drive.
    Does one have to replace the entire rear housing to replace the speedo drive?
    The Renault workshop manual, and Ball, Haynes, Gregorys, (and a couple of others) workshop manuals are of no use either.
    Ren
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,346
    Quote Originally Posted by REN TIN TIN View Post
    Ren
    As mentioned above after you have removed the bolt that secures the speedo cable, the speedo drive just pushes out. There is an O ring that is used as a seal between the drive and the housing, but usually they just push out fairly easily.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Simon's Avatar
    6,203
    Page 31.50 contains the speedo drive
    1963 Renault R4 Van
    1964 Renault R4
    Simon's Avatar
    6,203
    Quote Originally Posted by Ove View Post
    I missed this one from earlier. There does seem to be a loose correlation, but the attached pic shows that there can be exceptions. Two speedo drives with identical part numbers, but two different colours.
    Attached Thumbnails Attached Thumbnails R8/10 type 330 transmission speedo-dsc07679.jpg
    1963 Renault R4 Van
    1964 Renault R4
    Brisbane/Australia
    2,207
    Page 30.50, so it is.
    Thank you Simon, you have saved the day yet again.
    I must be going blind, I couldn't find.
    (In my defence , I've scanned the parts list so was looking in preview mode on the monitor so the drawings were small).
    Now to check the gearbox type and whether is a 13 tooth or 14 tooth.
    Ren
