Renault R4 suspension bushes wanted
Results 1 to 12 of 12
  • 1 Post By 4cvg
Thread: Renault R4 suspension bushes wanted
    Fellow Frogger! Balki's Avatar
    Sheffield/Tasmania
    633
    Default Renault R4 suspension bushes wanted
    Looking for 1965 R4l rear inner and outer suspension arm bushes, anybody have some old stock around as i cant seem to find anyone selling them new
    Via the aussiefrogs App
    2016 Cactus
    2003 Range rover l322
    1974 D special
    1971 D special
    1992 CX TGE Safari
    1961 ID19
    1972 DS21 Safari
    1965 Renault R4
    1923 Citroen B2
    1927 B14
    Massey ferguson 550
    1000+ Posts Kim Luck's Avatar
    Melbourne, Aus.
    18,563
    Their apparent rarity consigned one of my R4's to scrap back in the early eighties. Handling characteristics had become diabolically unpredictable on dirt roads.
    Simon's Avatar
    6,203
    Firstly, in all correspondence to parts merchants include the identity details for the car itself. There are numerous differences between an Australian assembled 1965 model year R4 and a French assembled 1965 model year car.
    The main identifier on an old Renault is the Oval Plate number. On an R4, the number is located on an obviously oval shaped plate located on the bulkhead adjacent to the bonnet latch (next to a diamond shaped chassis number plate). The oval plate number is the main identifier for the vehicle for parts purposes.
    The first place to try would be Renospeed in the UK, he has an indepth knowledge of R4's and if he can't supply, he will know who can:
    Welcome to Renospeed | Renault 4 Specialists | Renospeed
    Then it would also be worth popping the query on Clementine's R4 Forum: Clementine's Renault 4 Garage
    But don't forget to include the oval plate number to assist in identifying the correct parts for your car.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    Feb 2005
    rosevale/tasmania
    2,873
    If all else fails, what is the feasibility of crafting some polyurethane ones from "billet" (or modifying stock ones that are close enough in dimensions)? Peter
    niks likes this.
    Sheffield/Tasmania
    633
    Thankyou simon for all that info, will get in touch with them, i have thought of making some but would rather buy them of the shelf if possible
    2016 Cactus
    1974 D special
    1971 D special
    1992 CX TGE Safari
    1961 ID19
    1972 DS21 Safari
    1965 Renault R4
    1923 Citroen B2
    1927 B14
    Massey ferguson 550
    Sheffield/Tasmania
    633
    Okay tried renospeed could get anything i asked for, list was all bushes and front and rear window seal, so ill keep searching, any other sugestions?
    2016 Cactus
    1974 D special
    1971 D special
    1992 CX TGE Safari
    1961 ID19
    1972 DS21 Safari
    1965 Renault R4
    1923 Citroen B2
    1927 B14
    Massey ferguson 550
    Simon's Avatar
    6,203
    Quote Originally Posted by Balki View Post
    Could or couldn't? Assuming couldn't, did he suggest anywhere else? Also did you try a shoutout on Clementine's R4 forum?
    What type of suspension is it? Anchor lever or cam adjust?
    1963 Renault R4 Van
    1964 Renault R4
    Sheffield/Tasmania
    633
    Not sure what type, its a r1123 1965 model, didnt try forum will need to become a member first will give it a try
    2016 Cactus
    1974 D special
    1971 D special
    1992 CX TGE Safari
    1961 ID19
    1972 DS21 Safari
    1965 Renault R4
    1923 Citroen B2
    1927 B14
    Massey ferguson 550
    Oct 2002
    Melbourne Victoria
    12,669
    Icon14 a Picture is helpful in finding hard to get stuff
    A picture is often a good way of sourcing difficult to find suspension bushes, accompanied of course with suitable dimensions! Most of us who have a hoarding instinct (it might come in handy) do have at least one box or drawer of unidentified suspension bits and bobs that we have hopes of identifying one day and making someone happy
    Ken
    monbulk
    658
    I'm fairly confident that
    Der franzose*
    Melun Retro Passion
    will have the bits you need. From memory they are about 30 euro for one and 70 per bush each side (200euro) roughly $300aud*
    It's VERY unlikely that these 75-100mm bushes/ brackets will be found in old stock in the bottom drawer of someones filing cabinet in Australia.
    Good luck
    David
    Simon's Avatar
    6,203
    You WILL need to ascertain the fabrication number of the vehicle. As mentioned earlier, the main identifier on an old Renault is the Oval Plate number. On an R4, the number is located on an obviously oval shaped plate located on the bulkhead under the front bonnet adjacent to the bonnet latch (next to a diamond shaped chassis number plate). The oval plate number is the main identifier for the vehicle for parts purposes.
    I will bore people and bang on about it. The reason for supplying the fabrication number to parts vendors is important, because in 1966 there were significant changes to the rear suspension from an anchor lever type to cam adjustment. The inner rear bush and bracket for the early cars is different to that of the later cars, and the later type won't fit. If the perceived 1965 model year ID is incorrect, the wrong parts could be supplied. Therefore to prevent aggro to all parties, due to incorrect parts supply, it helps to accurately identify which parts are required for the intended vehicle by supplying the fabrication number (a likely six-figure number stamped below R1123 on the above mentioned oval plate).
    1963 Renault R4 Van
    1964 Renault R4
    Apr 2003
    249
    Plus one Simon. The trouble may also be that you can very easily change the rear end on the 4 so these numbers may even be irrelevant. Most sure way is to pull the parts out and get the old verniers out as there are MULTIPLE bearing sizes, lengths, protrusions etc.
