R10s or R12 Air Filter Assembly for RENAULT CARAVELLE
Results 1 to 11 of 11
Thread: R10s or R12 Air Filter Assembly for RENAULT CARAVELLE
    Feb 2012
    Vista SA
    986
    Default R10s or R12 Air Filter Assembly for RENAULT CARAVELLE
    Hi fellow R8,R10s and R12 froggers.
    I need your help!
    I have what I think to be a R10s OR modified R12 Air filter assembly fitted to my R8 which is connected to a twin throat Weber 32 DIR 4 down draft carburettor. And it works perfectly.
    Now I want to convert the old single throat Solex set up fitted to my CARAVELLE to the same set up as on the R8.
    I have the R10s manifold, I have the twin throat Weber Carbie and linkages, gaskets etc.
    What I need is a Carbie ''Air Filter Assembly'' that will go onto the Weber carbie, and I know I will have to modify it a bit to make it work, that's OK by me.
    What I'm after is the same set up as what is fitted to my R8 (see attached photos) so if anybody out there has an old R10s OR R12 Air Filter Assembly sitting around they don't want I would love to hear from you. I'm willing to pay for it and/or postage.
    many thanks
    philR10s or R12 Air Filter Assembly for RENAULT CARAVELLE-dscf2900.jpgR10s or R12 Air Filter Assembly for RENAULT CARAVELLE-dscf2901.jpg
    11,295
    Our Caravelle in Kenya had the twin choke Weber and appropriate filter, so the item should be around as a Caravelle part, but I agree it is probably exactly the same as a 10S or 8S item.
    I expect one or more of the likely suspects will come good! Jacques in USA might have such a thing too.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Simon's Avatar
    6,203
    JohnW is correct, what you want is an 8S/10S type, the 12 type is totally different and won't suit. Also the US spec air filter has a different base to suit the Solex type twin choke carby fitted to certain models, it is also unlikely to suit without a certain amount of modification.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    Feb 2012
    Vista SA
    986
    Thanks John. Hopefully something will turn up.
    Phil
    1000+ Posts J-man's Avatar
    Littlehampton, S.A.
    23,614
    What does the base of the original air cleaner look like Phil? Could you do a job on your original one and cut the centre out to suit. In other words convert it to a R10S air cleaner base?
    cheers,
    John
    Mar 2011
    Roselands
    253
    Hi Phil, I think I have what you want, will have to check, I have wrecked a couple of R10S's and have a bunch of stuff under the house. Won't be tonight, but will check prob tomoz and come back to you.
    I need your help!
    many thanks
    philClick image for larger version.
ID:	55942Click image for larger version.
    Feb 2012
    Vista SA
    986
    Thanks Simon. Yes it looks like I'll be modifying the one I have. Bit if messing around but I love messing around with my car bits.
    Cheers Phil
    Feb 2012
    Vista SA
    986
    I actually have a filter assembly of an early R10 and if nothing turns up, I'll simply modify it to suit the oval cutout of the weber plus the oil fume tube from the rocker box cover. Nice simple little project to keep me busy in between looking after Sally who bye the way is improving each day.
    Cheers Phil
    Feb 2012
    Vista SA
    986
    Wow 'renosprite', I'll hang out for you to check under the house. You might save me a heap of modification work.
    I see you are in Roselands NSW. My wife came from Kingsgrove so I'm very familiar with the suburb. We used to go to Roselands shopping centre all the time in my 1964 R8 back in 1968 to 1972, great shopping there hopefully it's still is.
    Thanks again for your time to search, let me know your sale price and I'll pay postage.
    Phil
    4,425
    Quote Originally Posted by RENOSPRITE View Post
    prob tomoz? what are you 21?
    totes amazeballs! LOL
    KB
    KB
    Feb 2012
    Vista SA
    986
    KB
    Sorry KB, can't understand your comment !
