Repairing rust on gearbox shaft
Results 1 to 10 of 10
    Fellow Frogger! IThompson's Avatar
    Sep 2011
    Bendigo / VIC
    226
    Default Repairing rust on gearbox shaft
    I have bought another R12 for parts which also came with an R18 gearbox and a pair of drive shafts.
    There is considerable surface rust on the gearbox splined output shafts. Should this rust be removed before use (i assume yes) and what is a good method of removal. Emery paper and a lot of patience?
    Likewise the splines on the drive shafts.
    On a side note is the R18 box going to fit in an R12? Or are the mounts too different?
    Ian
    8,480
    When i had a r12, they were doing the 5 speed conversions with r18 gear boxses so i'd say yes it does fit, but I'd assume a fair bit of fabrication will be needed.
    Re splines, I've always just brushed off the rust with a wire brush and applied a grease to the splines.
    Being a renault, they should be covered in gearbox oil fairly soon after being installed.
    Jo
    Dec 2010
    471
    Is your renault 12 automatic? Transmission hump for auto is bigger than the manual one and 5 speed will fit in auto car without modifying hump. You'll have to make your own mounts. Are the driveshafts you have shortened? Because the 18 diff is wider the shafts need to be a little shorter than standard. What Motor are you running? If it's a 17 motor 18 bell housing will work (although clutch arm is a little longer) but if its a 12 motor have to change bell housing and input shaft. Also, you'll have to make gear linkages.
    4,425
    Do what Jo suggests but for future reference on rust removal, for readily portable pieces google use of molasses solution for rust removal.
    I think there might have even been a thread on here as well?
    KB
    Simon's Avatar
    6,203
    The next stop after the output shafts inside the gearbox is the diff carrier bearings. If the gearbox has been out in the weather for some time, or has been pressure washed without the driveshafts in place, the bearings may have been contaminated by grit/moisture etc. Whilst the surface rust should come off relatively easily, bits of grit and rust could contaminate the bearings leading to a noisy diff. So, to avoid all that, and make the output shafts easier to clean, it is best to split the gearbox and replace the diff carrier bearings to be on the safe (and quiet) side.
    Also note that there are two types of gearbox, the early 18GTS with a Type 395, and the late 18GTS with an NG series 'box. Both have different gear lever methodologies, so it is best to find the matching bits to suit.
    One other thing worth bearing in mind. The 18GTS gearing is quite tall, I'm not sure if the early pre-1.4 Sierra 12 motor would be best suited to the gearing. I'm guessing in overdrive top it wouldn't be much fun. The best five speed would be a 365 from a 17TS/G, but those are quite (very) rare. If fitting the 18GTS 'box, you would be best also fitting the 18GTS motor, then the fun starts with modifications, vented brakes etc........
    And as specified above, unless it is an auto bodyshell, the hump in the floor of a manual trans 12TL/GL (as opposed to a 12G!) won't clear the rear of the 'five speed 'box, then also the various bellhousing/input shaft permutations........
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    Sep 2011
    Bendigo / VIC
    226
    Thanks,
    Looks like i made a mistake in buying the gearbox. I will store it. Either it will come in useful or someone else may need it.
    I wrongly assumed that the r12 and r18 were more closely related.
    The synchro on 2nd in my 12 gearbox is worn and it is difficult to change without crunching. I thought the other gearbox could be a replacement until i fix the first one.
    I have a gearbox in my second car. I will have to look at removing that one instead.
    Ian
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,331
    Quote Originally Posted by IThompson View Post
    Sounds like the energiser spring on the 2nd gear synchro ring is broken, this is a common fault with these gearboxes.
    Its a fairly big job to fix, you need to spit the gearbox and remove the bearings and gears off the secondary shaft. I'm not sure if new springs are available anymore?? but I have used second hand ones before.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Boonah Qld
    2,632
    Changing the gearbox oil for Castrol VMX 80 is worth a try. Incorrect gearbox oil causes just such a problem. If not too much damage has been done you may be lucky. The new oil will take about 150 - 200 kilometres to take effect. The problem relates to a chemical that attacks the brass syncro's in these gearboxes. There has been many pages written on this subject on Aussie Frogs previously.
    11,293
    I got some from Ken at Caravelle a few years ago for the R8 - a 10S box in my car. Same as R12 I presume. They aren't shown on Mecaparts catalogue. Chase up the gearbox folk - call Colliers perhaps, Dauphproto on this forum. I'd be surprised if you can't get them as they surely do break, sometimes with catastrophic results. But they aren't shown on the usual sites I get parts from.
    Brave to use secondhand ones Col. Lot of work....
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,331
    I was working on the principle that if the energiser spring looked in good condition and had lasted for 30 years it would last forever
    Regards Col
    1973 Alpine A110
