Replacement Distributor for my 1968 R10 running a R12 engine type 842-01
Results 1 to 23 of 23
Like Tree3Likes
  • 1 Post By R8philSA
  • 1 Post By J-man
  • 1 Post By JohnW
Thread: Replacement Distributor for my 1968 R10 running a R12 engine type 842-01
    Member Rob Caris's Avatar
    Mar 2014
    Shailer Park - Brisbane QLD
    37
    Default Replacement Distributor for my 1968 R10 running a R12 engine type 842-01
    Hi
    I am very new to this site and have just had my 46 year old 10 arrive Just asking for some advice please - Can I just replace the current Bosch distributor in my 68 - R10 with a new ducellier Distributor Car as an Australian spec R12 motor from memory when I purchased my R12 in 1973 they were 1251cc. This jigger could now be 1289cc as a fellow frogger pointed out a couple of weeks ago if it has been resleeved.
    The engine is running really rough and will not idle only unless it has resonable Choke applied, there is play in the Distributor shaft and the rotor is pretty loose as well..
    I think the best thing would be to replace the lot - New Dist, Points, Rotor and HT leads and adjust timing. If that doesn't work - I will then look at the carby I guess. In my enquiries have confirmed that a new Ducellier Distributor is more readily available for the R12 engine - Ken from Caravelle imports seems to be very helpfull in this respect.
    Any assistance is greatly appreciated...
    Rob C
    4,427
    Have a look at the Ignition123 distributors.
    The aust agent wants about $550 for them but you can get them from Europe.
    Before spending too much money though, I would look at getting it tuned by a Renault specialist workshop (not a dealer though) someone like French car care for example.
    KB
    It's how I roll...Brisbane
    33,992
    I'd be checking the carby for vacuum leaks too. Since it needs lots of choke to idle indicates to me that the idle circuit isn't working because of lack of vacuum possibly from a bad gasket or more likely a worn throttle spindle..
    Every day when I wake up I reach up in the darkness with my eyes shut and if I cannot feel anything that resembles a wooden lid I know it will be a good day. No lid today.
    11,310
    Be a bit careful there. The 123 for Renault is not specified for the R8/10 but the same "general" engine as used in FWD cars and DAF55. One of our number in WA has one and it simply doesn't work properly with his R8. If one of the "Tune" models fits, it would be a different story, as you could get the advance curve correct. But his is one of the multi-switch type and apparently none of the curves suit the car.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    11,310
    And, I completely forgot to say, check ebay France. Here's a brand new Ducellier for an R4: Renault R4 Allumeur Ducellier Complet Neuf Origine Renault 77 00 720 887 | eBay
    Search for "allumeur Ducellier" and R8 and R10. You never know your luck.
    Feb 2012
    Vista SA
    986
    I have just taken delivery of a 50 year old Caravelle. Took 10 starts and stops to move it from the front of the house to the back and then it only got there by giggling the accelerator and clutch. Air filter off and a look down the throat of the SOLEX told me the accelerator pump was not working at all. Also sever lack of power. Ripped the top half of the carbie of and took out the accelerator pump tube and delivery nozzel and blew them through until it unblocked. Also the internal passages within the accelerator circuit. Then out of interest I looked into the bottom of the float bowl to find about a 6-8mm of white sediment built up just covering the main jet from time to time while running. The car had been sitting for many months and the carbie bowl had oxidised, naturally when I gave it the fuel it all went into a milky mixture. Don't ask me how the transporters got it up the ramps of the truck, must have gone up there at about 6000rpm riding the clutch.
    So I cleaned it all out, change the external and internal fuel filters and gave it a start. RESULT: Prrrrrrrrrrrrrrrrrrr like a kitten
    Cheers, hope this helps if the dizzy doesen't.
    Phil
    J-man likes this.
    Simon's Avatar
    6,203
    There are a number of different types of distributors fitted to the early motors. Also what carby does the car currently have? A single choke "something" or 32DIR twin choke downdraft Weber?
    Various Bosch dizzys:
    Type Number 9230062404, Renault number 7702050020 fitted to the 842-01 motor, initial advance setting 0+-2 degrees, 48+-2 degrees dwell.
    Type number 9230062409, Renault number 7702063120 alternative fitted to the 842-01 motor, initial advance 60+-2 degrees, 48+-2 degrees dwell.
    Type Number 9230062407, Renault number 7702062934 fitted to the 842-05 motor, initial advance 0+-2 degrees, 48+-2 degrees of dwell.
    A few people give the old Ducellier a bad rap, but apart from worn bob-weight bushes and worn spindle bushes from old age (don't forget to oil the felt button under the rotor arm occasionally), I think they are a good little thing.
    For a 12 motor the Ducellier distributor is marked with both the centrifugal and vacuum advance curves, of which there are a few types depending on the motor.
    The 810-02 motor (single choke carby) has a Ducellier dizzy with R251 centrifugal curve and C34 vacuum curve, then there is an alternative type marked R268 C34.
    The 810-05 motor (Weber carby) is marked R248 C34, the auto trans version R280 C34.
    Really though, KB has the best initial solution, get someone knowledgeable to look the car over, and identify what needs replacing. It will likely be a lower cost solution than simply throwing money at new components only to find something else is causing a problem. Things like non-standard or missing breather hoses can also cause running issues, so there are a plethora of different things that can cause problems in an older non-standardish car.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    11,310
    Phil
    Always good to have a compressor eh Phil....
    I'd buy a new fuel pump "avec levier" too. I have one on the R8 and the 4CV, and it is so satisfying to pump fuel up knowing how much less work the starter and battery will have to do. For an intermittent use car, they are brilliant.
    1000+ Posts J-man's Avatar
    Littlehampton, S.A.
    23,655
    As mentioned, I'm thinking mixture problem too, given your choke remedy. I'd blow out the idle jets or go further like Phil did
    cheers,
    John
    Mar 2014
    37
    Thanks gents, Simon your info is so detailed. Mate the engine in this little r10 is an 842-01 isn't that an early 1251 cc ?
    when I got my 1st r12 in1973 it was a pale grape coloured 12 GL -that had a 1251cc with a single throat solex carb -later changed to a 40 DCOE weber side draft - I ran sooo much better.
    this engine in my 10 could by now --- be a 1289cc re sleeved .... It has a 32 DiR weber twin throat down draft carb and standard R12 air cleaner.....
    I guess in simple terms - it's probably best to just replace the distributor question is - Bosch or Ducillier? Where can one get a new Bosch disi?
    I will get a small mirror to see if the part number matches the original Bosch type number 9230062404 you have quoted.
    surly they can still be sourced new?
    Thanks everyone
    Littlehampton, S.A.
    23,655
    I used to love those lever fuel pumps - just great
    cheers,
    John
    Simon's Avatar
    6,203
    Quote Originally Posted by Rob Caris View Post
    Unless you find a complete one as NOS, I think it will be difficult to source a complete new Bosch version of the desired type. OTOH, an old school Bosch workshop/auto electrician may be able to rebuild and re-graph the Bosch using NOS parts if they have any, given the internal actual components were used on a number of other Australian built cars using Australian Bosch components. Then comes the issue, is it cheaper to rebuild the Bosch, or buy a new Ducellier, and if required, get it re-graphed to suit your requirements?
    It sounds like your motor is a bit of a mixed bag according to its equipment and the engine data plate. Then there are other things like has the 1251cc 8.5:1 compression head been shaved, or replaced with a 9.5:1 compression head........ In which case an 842-01 dizzy may not be the optimum.
    Also check the Weber for the idling jets (and if an idle jet or two has dropped out), breather hose security (especially if it is using the R12 Weber manifold and fittings), loose securing nuts, warped carby base, etc that can cause poor idling issues.
    1963 Renault R4 Van
    1964 Renault R4
    321
    G'day Rob,
    you may or may not have seen my parts sale here: Reno 12/15/16/17 Parts Clearance Bargains!!
    Picture 6 are the dizzy's I have; the one in the right of the picture is a Ducellier No P268 C34 as mentioned in Simon's post (No.7) above.
    It comes complete with points, rotor and leads. If interested let me know.
    Philip
    Apr 2011
    Melbourne, Australia
    176
    Hi Rob,
    Have you though about getting the original distributor rebuilt? I got my 750 one rebuilt many years ago, by the people who sold "Yella Terra" cylinder heads. There are probably people around who still do this kind of work. As well it supports home industries!
    Regards
    David
    11,310
    Quote Originally Posted by DJ 750 View Post
    Hi Rob, Have you though about getting the original distributor rebuilt? I got my 750 one rebuilt many years ago, by the people who sold "Yella Terra" cylinder heads. There are probably people around who still do this kind of work. As well it supports home industries! Regards David
    That's a fair suggestion actually, if you can find someone with a proper distributor bench to set up the advance curves. It's "only" a matter of a few small bushes and pivots being refurbished. For a 4CV distributor, there's a bench in Paris, but he doesn't have the drive attachment for the later Ducellier distributors unfortunately.
    Have you contacted the Renault folk in Brissie?
    11,310
    You might try Bretagne Auto Retro too - they seem to have some new distributors: bretagneautoretro.fr
    Littlehampton, S.A.
    23,655
    Pretty sure John from Kent Town Auto Tune can reco yours and set it up for you. Bit of freight from Adelaide though. All he does is set up old cars on his dyno and he has plenty of early Renault experience too.
    Kent Town Autotune
    6 Little Rundle St, Kent Town SA 5067
    (08) 8362 4906
    cheers,
    John
    11,310
    Quote Originally Posted by J-man View Post
    Kent Town Autotune
    (08) 8362 4906
    Wow. John Hurley is still there??? Excellent guy. Just excellent.
    Littlehampton, S.A.
    23,655
    Yep, but he's not interested in doing EFI or turbos, just old school with carbies. Good on him I say
    Wildebeest likes this.
    cheers,
    John
    11,310
    I should slip over and get the Citroen CX tuned up.
    J-man likes this.
    19,225
    Kent Town Autotune
    (08) 8362 4906
    At around $A180 plus freight a new distributor assembly may be a better option?
    It doesn't take much to run up quite a bill with new points, cap, rotor and sorting the bob weights and of course the labor.
    9,340
    If the carby has play in the shaft I would say that's the starting point. Everything else will help just emphasize how bad the worn shaft (or bushings) are. There are places where they can re-bush the carby and give it a proper overhaul which will see it a s new. Don't know any mob in Brissie, but the mob in Adelaide (Kent town) is pretty good. they rebuilt a few of my carbies to original spec.
    One thing I have done myself was to replace such bushings with teflon sealed ball bearings. You can get these in a variety of sizes from a good hobby shop (radio control helis and such seem to use some really high tech ball bearings) and given your application these might actually outlast the car. I used really sticky silicone grease (the real Molykote stuff) to pack the bearings and never had a problem again. No play and the shaft was smooth as butter. This stuff doesn't dissolve in anything, and it's sticky as the proverbial, the only problem is to get the bastard off your fingers.
    With the dizzy, I would go to a bosch local with a good core example which some of these places can do wonders. There is such a place just around the corner from me, but I'm in the wild west, a bit far from you. I'm sure a bit of digging might unearth something closer to you.
    If your romanian serves you well, you might be able to get some unobtainium bits and pieces like dizzies, carbies, etc. Not sure the quality.
    ACHTUNG ALLES LOOKENPEEPERS
    11,310
    That's interesting. Exactly where did you get the bearings please? And where exactly is the "bosch local" please?
    These things get to the stage where several things are bad at once, don't they...
