Scenic ride height
Results 1 to 7 of 7
Like Tree2Likes
Thread: Scenic ride height
    Brisbane/Australia
    2,202
    Default Scenic ride height
    Does anyone know if it's possible to adjust the rear springs on the Scenic (JA).
    My car is sitting about an inch lower on one side.
    There were cams on 16's I had that you could turn to adjust the torsion bars and consequently the height.
    The Scenic has torsion bars too so I was hoping the good people at Renault might have included some method of adjusting the spring.
    I had a look under the back but there didn't appear to be anything there that looked like it could adjust the spring.
    I suppose I could put a bag of cement or two on the opposite side to even it up but that's a bit messy.
    Ren
    8,484
    Quote Originally Posted by REN TIN TIN View Post
    Ren
    Wet it first.
    I didn't know the fwd scenic had torsion bar rear. Just assumed it was the same as the rx4, which has springs.
    Jo
    Brisbane/Australia
    2,202
    Yep, torsion bars at the rear.
    The 4WD doesn't have room for torsion bars because of the rear diff hence the coils.
    The rear driveshaft would have to go through the middle of the torsion bars.
    I think the later Scenic models have coils on all corners, don't know why the earlier ones had torsion bars.
    Perhaps it was a carry-over from the Megane that these were derived from.
    Ren
    P.S. Don't think I'll go with wet cement, it's a bit hard to remove once the springs are fixed.
    Perhaps I'll find a sumo wrestler to carry around as a passenger to even out the springs.
    tweed heads
    1,544
    I have a workshop manuel down loaded somewhere i will have a look ,probably just have to turn it up a coupla splines on the torsion bar ,pugs
    Mar 2011
    Linton.Victoria.
    1,282
    Torsion bar failure perhaps?
    1000+ Posts Kim Luck's Avatar
    Melbourne, Aus.
    18,563
    It could have had some of the suspension replaced by a no-clue owner, panel beater or similar. I've had a panel beater want to stretch one side of an R16TS so that the wheelbase was equal on each side. They were a bit nonplussed as to how it got out of alignment in the prang....
    11,302
    Quote Originally Posted by Kim Luck View Post
    I missed that post Kim. Memorable.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
