R12 Specs
Results 1 to 10 of 10
Thread: R12 Specs
    Mar 2011
    Roselands
    253
    Default R12 Specs
    Looking for some help, I have an R10 with R12 engine, 842-01 is the capacity 1289cc
    RC
    4,425
    I believe so, Yes.
    There was a smaller R12 engine (a sleeved version of the 1289) but I think it would have used a different code.
    847 is a 1397cc engine
    There was a list I found googling engine codes, probably also on here too?
    KB
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,333
    Quote Originally Posted by RENOSPRITE View Post
    RC
    Its 1250 cc.
    Heres a link with R12 specs Quick Reference - Maintenance Data Renault 12
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Member Rob Caris's Avatar
    Mar 2014
    Shailer Park - Brisbane QLD
    37
    Hi Roger
    I noticed your post on the 12 engine thanks for that 1251 in the rear end of a 10 should still be a good performer. Same engine I had in by 73 12 GL. Now 8 need to have the experts advise if I go with twin weber 40 DCOE carbs and wher to find inlet manifols.
    And Col thank you for your info. Had a look at the site you linked in pretty comprehensive stuff. Appreciate the feedback.
    by the way I am new to this site as I am about to become the new owner of a 68 10 same as my first car back in 1973 a 89 10 followed by a 12, 15, 16, 17, and two Fuegos . I will definitely be looking for some expert advice and guidance. Cheers Rob Caris
    Simon's Avatar
    6,203
    Don't forget that the 842-01 and 842-05 motors were for the Australian assembled cars only, and that most are likely to have been rebuilt at least once in their lives. Given that the 1,289cc piston liner kit was the usual replacement, if they have been rebuilt most are now likely to have a few more CC's than stock.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    Mar 2014
    37
    Hi Simon
    I suppose that's a big possibility but there is no way of confirming this unless I try and investigate back to the prior owners ..
    It really doesn't matter for now I am just pleased I have the Reno to look after and tinker with. Thanks mate
    4,425
    Probably just good advice that next time you need to take the head off for any reason (or rebuild the motor) to measure the diameter of the liners and get the piston size. If we're talking about the white R10 with the red stripe, I know the last two owners and I don't think either of them rebuilt the engine during their ownership. I suspect that line of enquiry will draw a blank.
    I think there would be little horsepower advantage between 1250, 1289 and 1397 engines. The smaller engines are usually considered better as they are better balanced and rev harder. I had mine on a chassis dyno (1397) against someone with a 1289, both worked engines and the difference was 0.8hp. Same dyno, same day 10mins or so apart.
    KB
    Fellow Frogger! rubyalpine's Avatar
    Christchurch, New Zealand
    493
    I would only fit twin 40 DCOE's if I was building a really racy motor. For most "warm" road applications, a single DCOE or a twin choke down draught is quite suitable. For the down draught option, inlet manifolds are more readily available, ex R12TS, R10s, etc. with the best d/d carb option being 36DCD, or 28/36DCD (ex pre-crossflow Cortina GT). these carbs are more easily tuned as they have removable choke tubes which are available in various sizes.
    Henry
    4,425
    I would agree with that 100%. I went down this route 12-18mths ago and could not find any twin weber manifolds commercially available except the slight chance of one in south America which were not only hard to get but would have worked out extremely expensive ($1000US was quoted). I looked at several options locally to be fabricated and ended up with a combined inlet/extractor setup which was the best part of $2000 on the car. The cost, effort and hassle involved is not worth the benefits obtained.
    KB
    Fellow Frogger! R10S FAN's Avatar
    Mt Barker S.A.
    391
    But geez KB, it looks bloody great!
    Current Frogs:
    1964 Renault 8 (1289 / Sonics)
    1968 Renault 10 (Modified 1.4L Alpine White)
