Fuego instrument cluster
    MELB
    35
    Default Fuego instrument cluster
    Hi, is there a common problem with fuego instrument cluster. Only thing working is fuel gauge and speedo. I have checked the fuse. As well can you still get instrument needles anywhere.
    Thanks. Peter
    Oct 2005
    vic
    868
    Had my needles replaced by Ringwood Speedos.
    Wasn't overly expensive.
    The other problem with dash means (more than likely) you have to drop down the fuse panel and remove and refit electrical connectors a couple of times (or use contact cleaner or the old style ink rubber).
    They tend to get dusty and removing/refitting them exposes fresh contact surface restoring electrical connections.
    If that doesn't work we'll have to investigate power supply to cluster.
    Hop this is a start.
    David
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,353
    Hi R1173
    I have used R16 speedo needles (these are white but they slip straight on).
    Like 85Fuego said most likely you will have some bad connections somewhere, just beware with some contact cleaners that they will melt some plastics so before you go crazy with the contact cleaner test on the plastics first.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Simon's Avatar
    6,203
    VK & VL Commodore needles also used to be a replacement for the warped Fuego needles.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
