R25 crossmember
Results 1 to 14 of 14
Thread: R25 crossmember
    farmerdave
    Guest
    Default R25 crossmember
    Check those crossmembers...
    the crossmember under the gearbox/bellhousing of my R25 is badly bent, looks like jack damage (jack did it ). (actually the gearbox is out of the car at the moment having its internals scooped out and rebuilt because a PO ran it without any oil in it until it stopped DUH I'm not sure how you do this without noticing, but she did )
    I had a look at 2 other R25s today, and they both have the same sort of crossmember problems. I'm concerned, because the crossmember looks like it may be structural. Straightening it will be a beast of a job, drill out the spotwelds, cut through the weld seam on the outside edges, straighten, reweld etc. Is it worth worrying about/fixing ?. Is this a common problem?
    Farmerdave
    1000+ Posts Europa's Avatar
    Jan 2002
    2,432
    Not sure about everyone elses crossmembers, but my V6 one just unbolts. I know this because I bent it with a jack when replacing the auto computer. I think 4 x 19mm bolts with captured nuts from memory.
    Easy enough to straighten once out of the car.
    I can provide a photo if required as it isn't currently fitted whilst I'm working on the motor.
    Fellow Frogger! deja vu 25's Avatar
    Jan 2002
    657
    Yes, the GTX crossmember also unbolts. I have yet to see an R25 that it has been straight on.
    My V6, Mr Maroon GTX, Mr current GTX and my spare parts car GTX all had this.
    Cheers - Luke
    1990 Renault 25 V6 Baccara - Gunmetal Grey
    1974 Renault 17TS (1317) - Silver
    farmerdave
    Guest
    Just to clarify, the crossmember does bolt on- my comment regarding welds was in relation to the spotwelds holding the two pressed metal pieces together.
    Separating the two pieces to straighten then was a bit simpler than expected, it took about an hour to separate, 15 min to straighten and another 15 to mig back together.
    Jan 2002
    2,432
    Quote Originally Posted by farmerdave
    Mate, bash it straight, she'll be right. Unpicking spotwelds? Bah!
    Oct 2003
    Hampton Park
    523
    The cross member is "structural" my 20's was loose and the front end fely twitchy over bumps, the problem went away when I tightened up the cross member bolts.
    Jan 2002
    2,432
    Quote Originally Posted by Sherman
    hehe well, now we are off topic (ie. R20 not R25), I also notice that my R17 feels a lot better when the sump guard is attached. Seems to tie everying down well. Pretty heavy bit of steel, and a nice shape.
    Oct 2003
    Hampton Park
    523
    Quote Originally Posted by Europa
    Not quite off topic, there isn't that much difference between 20 and 25. I agree with your comment about the 17 sump guard, both my 17's have their guards intact. Makes me wonder about my 20 which has its sump guard missing. Anyone got a spare?
    Jan 2002
    2,432
    Did R20's come with sumpguards in Australia? Or had Renault reclassified Australia by then (no longer a "poor road" classification)
    Simon's Avatar
    6,138
    There was no guard as such fitted to the 20, the 12/15/17 models were the last of the extreme poor road cars to come to AUS. The 18/20 had fewer poor road features. The sumpguards fitted to the 12/15/17's were part of the special equipment here and for places like Africa, and were not fitted to the Euro spec cars.
    Oct 2003
    Hampton Park
    523
    Quote Originally Posted by Simon
    I have owned two 18s (breaks) and they both had sump guards. The 20 I own has "loose" captive nuts where the s/g would go, with bolts in them. You could be right but it sure looks like one has been taken off.
    Simon's Avatar
    6,138
    Sounds like the ones you had are different to the ones I've seen. They were basically a tin skid plate not like the heavy solid guard on the old 12's
    Oct 2003
    Hampton Park
    523
    The 20 may have had a thin skid plate as I have never seen anything where a sump guard should be. The 18s had 12 type s/gs.
    Jan 2002
    657
    The 20 may have had the thin plate you mention, but my first GTX had only a plastic sump guard - that really tightened up the front end - LOL
    Cheers - Luke
