crankshaft difference
Results 1 to 2 of 2
    Jul 2011
    ungarie
    26
    Default crankshaft difference
    Back again
    Is there any difference between Gordini crank, rod, piston & rings from a Dauphine 850?
    Regards
    Phill
    Simon's Avatar
    6,139
    The crankshaft of the 670-05 Gordini motor is manufactured to tighter tolerances, with roll-hardened crank journals.
    The conrods for the later Dauphine Normale and the Dauphine Gordini motor are the same, however there are different weight grades. So all four conrods must be the same weight.
    The pistons and rings are the same for both the Dauphine Normale, and the Dauphine Gordini R1091. They were upgraded from four ring pistons to three ring pistons circa 1960.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
