Transmission Calibration
Results 1 to 8 of 8
    Nov 2011
    Camden
    14
    Default Transmission Calibration
    Do I need to have Renault dealer calibrate the transmission in '01 Scenic or can a independent workshop do it? Also what should it cost approx. ? Thanks Greg
    Jan 2005
    Melbourne NSW
    813
    What do you mean by "calibrate" exactly?
    Current stash
    too many.
    Passed over stash
    lots.
    1000+ Posts Kim Luck's Avatar
    Melbourne, Aus.
    17,783
    I'm aware that electronically controlled gearboxes (like engines) can have different mapping. The gearbox normally is self calibrating and shouldn't need any attention for the life of the car apart from normal service. Renault Electronic Automatics have been self learning for some time and will generally adjust to the way you drive; i.e: give them a lot of trailing throttle and they will change down as you approach lights, use the brakes fiercely and they probably won't. Hit the gas at every opportunity and they will hang onto the gears until the red-line. You are the one that calibrates the gearbox!
    Nov 2011
    Camden
    14
    I should have described it as re-calibrate or reset transmission. I've been told the car with 200k Km's from previous owner/s, would benefit from going back to factory setting, and then become adaptive to my driving style.
    Also occasionally the auto warning light will come on for no particular reason, when the service dealer/workshop hooks the car up it may show some error codes.
    Melbourne, Aus.
    17,783
    The box could benefit from diagnosis, anyone else have anything?
    1000+ Posts Haakon's Avatar
    May 2002
    canberra...
    8,657
    Read this (its called the AL4 in PSA cars, DPO in Renault, same transmission).
    AL4 Transmission
    Error codes mean an error (or electronic ghosts in the multiplex..). Auto adaptive just means it will learn which of the preset maps you spend the most time in - not sure an unlearning of that will help.
    tweed heads
    1,483
    Page 30 chapter 6 ,old oil warning light ,this is interesting as the tranny is supposed to be filled for life ,great link ,run out of time now ,will read up tonight pugs
    Newcastle
    2,572
    Quote Originally Posted by pugwash View Post
    Hi The oil temperature and time is monitored and it may be deemed to be over the specified limit and therefore a changes is deemed necessary. As far as the learning goes. The drivers actions are always monitored to determine the right preset map to use as haakon said. Nothing needed to be reset there. As well the computer does monitor the condition of the transmission by the way the pressures change during changes. It modifies the way it applies the pressure and speed of application to compensate for wear in the clutches etc. This should not be reset until the box is rebuilt or the like. Cheers Jaahn
