virage pulley
Results 1 to 11 of 11
Thread: virage pulley
    Dec 2004
    VICTORIA
    83
    Default virage pulley
    Hi: I need to replace the seal behind the main pulley at the bottom front of the engine. How do you undo the big nut at the front without having the pulley spin on you?
    Geoff
    1000+ Posts J-man's Avatar
    Littlehampton, S.A.
    23,619
    Hi Geoff, if you mean how do you stop the crank from turning while trying to loosen the crank pulley bolt, I normally use a large half inch breaker bar on the socket and position the breaker bar against the chassis. Then click the starter to release the bolt tension.
    cheers,
    John
    8,482
    Quote Originally Posted by Geoff Stewart View Post
    Geoff
    Rattle gun.
    Jo
    Feb 2001
    Romsey, Victoria, Australia
    4,904
    Quote Originally Posted by J-man View Post
    Geoff, if you don't have a rattle gun do what J-man says. Thats how we do it.
    David Cavanagh
    03 9338 8191 or 03 93354008
    34 KING St
    AIRPORT WEST
    VIC 3042
    frenchconnect@bigpond.com
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,334
    Geoff
    Hi Geoff
    I use a 19mm ring spanner and a copper hammer, a few good taps in the anti clockwise direction usually works.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    11,299
    Geoff
    I also use the mallet and spanner shock approach, like Col. I'm not as refined though and use a big steel mallet.
    I'd never thought of using the starter as a rattle gun.
    It just needs one good shock and it will free up completely.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    9,319
    Either as above or have the car in reverse and an assistant put their foot on the brake and use a long breaker bar. Rattle guns don't fit in there with the engine in car.
    ACHTUNG ALLES LOOKENPEEPERS
    Member ScottR's Avatar
    Apr 2011
    Yaroomba
    34
    We've used Jman's method a few times on stubborn ones.
    Littlehampton, S.A.
    23,619
    Geoff, if your pulley is anything like mine, you may want to grab yourself a speedy sleeve for the pulley while you're doing the seal. Both cheap and readily available through CBC.
    cheers,
    John
    Dec 2004
    VICTORIA
    83
    Thanks everyone. Having been away from the Renaults for a while you forget that they are bit smarter than they look. After reading the above advice I went to try and put my socket driver on the bolt and found that I didn't have the room to get it between the chassis and the bolt head, I stuffed around for a while and then realised that the cleaver little fella's had put a hole in the front of the Chassis so that I could put my socket driver extension through the hole and onto the bolt head, it was then just a matter of resting my driver under the bumper. One turn of the starter motor and the bolt was as free as a bird.
    Everyone.
    11,299
    Everyone.
    Ah. I didn't know that! My R8 of course has a crankhandle hole which serves exactly the same purpose.
