cylinder liner removal.
Results 1 to 25 of 26
Thread: cylinder liner removal.
    Oct 2012
    601
    Default cylinder liner removal.
    I'm sure this has been answered in the past, but I've searched and the best I came up with was get a hard wood drift and whack it with a big hammer. Well there is no fear of them just falling out when you flip the motor upside down, mine are well and truly stuck.
    Are there any methods I should know about other then the timber drift method as I'm just filling my motor up with wood chips. Its an 847 if that makes any difference. As fas as I can figure there is not much mechanical support other then the lip at the bottom and the o-rings. Should I be able to see a gap between the liner the block when looking from the bottom? Or is this a tight fit?
    Christian
    1000+ Posts J-man's Avatar
    Littlehampton, S.A.
    23,613
    Hi Christian, I filled mine with wood chips too, so I resorted to a brass drift
    cheers,
    John
    8,481
    You guys need better wood.
    Try hardwood, and hard harwood at that. Then you can use a bigger hammer.
    No gap can be seen, or else your coolant would fall down that gap into the oil sump.
    Jo
    Oct 2012
    601
    I'll go in search of some harder hard wood tomorrow. There is plenty to work on in the mean time. And I'm using a 4lb baby sledge hammer, not sure I want to use anything any bigger
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,331
    They can be a bugger to get out sometimes, especially if they have been in there for 30 years.
    Just takes persistence with some hard wood and a hammer.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    11,294
    And maybe a bigger hammer. It's like the parallel enquiry about the crankshaft pulley bolt. It needs a really good shock sometimes. Get some good old growth jarrah and a mallet that is about half sledge hammer head size and really whack it. A little carpenter's claw hammer won't do it.
    A big brass drift would do, but I'd always want the shock transmitted over the whole circumference of the sleeve. Even though brass is softer than steel, that doesn't mean you can't break it if hitting sideways.
    You could help it with the use of WD40 applied regularly for a month or two as well. Are you in a rush?
    Good luck.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    11,294
    There's a thought. 30 years. Mine haven't been touched since I rebuilt the R8 engine in 1988. So that's 25 years. Good coolant mind you.
    Boonah Qld
    2,632
    I too split even hard hardwood last time but I found a piece hard nylon and belted that. The liners had been glued in with some sort of gasket goo even down the sides.
    1000+ Posts Frans's Avatar
    Auckland
    1,553
    It is easy. Use MOT 000. Designed and made by me.
    I have a few pieces of aluminium (3 at the moment and might become more) that is cut to be the same as the liner at the bottom. Then I have a thick bar that lies diagonally across and above the liner and and is bolted down by a main bearing bolt on either end. In the center of this bar I have drilled a hole and tapped it M12. I then screw a M12 bolt in and it pushes on the aluminium bar lying neatly on the liner. I then just start turning it with a socket wrench and it acts like a pusher rather than puller and pushes the liner out. Has not failed yet.
    I will then bolt the bar across the next liner using the next 2 main bearing bolts.
    It takes an hour or two to make it but it works and can be used over and over again.
    Frans.
    Old enough to know better
    Young enough to do it anyway.
    Member dauphproto's Avatar
    Jun 2012
    Perth Scotland
    68
    All Perfectly good suggestions
    Beware it is real easy to crack a liner at the base and equally easy to not see it and have lots of problems later !!!!
    If you have access to a space heater cook the block for 45 mins that should help if there is any sealant down there you can't see
    I would go with wood and fill the block with splinters it takes time,but does no damage
    When the liners are out you can check them by holding lightly between thumb and forefinger and tapping with something metalic,they should ring, if they are dull (like hitting lead ) check for cracks
    Make sure you do this no more than a couple of inches above something flat and soft (yes I was the idiot who broke a liner while crack testing it!!)
    cheers
    Well if it was easy everybody would do it
    11,294
    Frans.
    Neat. Photo?
    11,294
    Quote Originally Posted by dauphproto View Post
    cheers
    I'll bet you're no orphan though.
    Jun 2012
    Perth Scotland
    68
    The man who never broke anything never made anything (proverb)
    I will get the pics of the rear suspension done I PROMISE when the weather eases up a bit
    4,425
    I made a little frame to help get them out. I'll put up a photo later on.
    KB
    Oct 2012
    601
    I got them out, but it took about 2 hours. I used a very hard piece of hard wood to get them out to the point where they are flush on the sump side, they still wouldn't move. Now for the part that took all the time, I used a brass drift, which I had to file back lots of times as I kept breaking the edge off it. There was no way they were going to just fall out.
    I know all about o-ring pressure seals, I work in underwater robotics where seal failure can be quite catastrophic, but these where so tight that I think the o-ring could have been left out and they wouldn't have leaked at the pressures involved.
    Speaking of o-rings, does anyone who what material and size they are meant to be? Or if they are an odd ball size.
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,331
    The "O-ring" seals will be in the gasket set that you will need to re-build the engine.
    Regards Col
    1973 Alpine A110
    4,425
    I think 1.4 are the genuine rubber "O-ring" as COL says, the others used the plasticy-paper spacers as far as I know.
    KB
    8,481
    I buy cylinder O-rings from Caravelle imports.
    Cant say he has ones for your motor but worth a try.
    Jo
    Littlehampton, S.A.
    23,613
    I may have a spare set. Sing out if you get stuck and I'll have a look.
    cheers,
    John
    1000+ Posts geckoeng's Avatar
    Perth, WA
    1,765
    Hi Guys,
    Sorry to have taken so long but could not find my 1400 tool and had to make one for the 1300G. The G sleves were glued in with green sealer all on the skirts. A good gentle blow (2 to 3) with a 4lb instrument on the tool and the sleeves were out. Very similar with my 1400 R5G/A, they were in tight and a similar tool did the trick.
    cylinder liner removal.-liner-extractor-1.jpgcylinder liner removal.-liner-extractor-2.jpg
    Ray
    Ray geckoeng
    Think Old, But Run Modern !!
    It's how I roll...Brisbane
    33,944
    Nice one Ray, I'll probably need to make one for my Fregate. I already posses a 4lb 'instrument' so just need the drift...
    Every day when I wake up I reach up in the darkness with my eyes shut and if I cannot feel anything that resembles a wooden lid I know it will be a good day. No lid today.
    11,294
    Hi Guys,
    Sorry to have taken so long but could not find my 1400 tool and had to make one for the 1300G. The G sleves were glued in with green sealer all on the skirts. A good gentle blow (2 to 3) with a 4lb instrument on the tool and the sleeves were out. Very similar with my 1400 R5G/A, they were in tight and a similar tool did the trick. Ray
    Glued!! Good grief. I can understand why you made the tool. I've always managed with a brass drift and a few sharp whacks just to break what little adhesion had developed. But glued....
    Fellow Frogger! rubyalpine's Avatar
    Christchurch, New Zealand
    493
    I've recently stripped my spare motor, and found that a piece of aluminium square tubing did the trick. I'm sure round section would be just as good. Hard enough to transfer the "shock " from the hammer, but soft enough not to crack the sleeves.
    Henry
    33,944
    Thanks for the tool tip Ray, here's my version.
    Having a long handle makes it a cinch and no damage occurred to the liners or my fingers.
    Perth, WA
    1,765
    Well there you go then ......... !!!
    And my mother used to call me stupid !!!!!!!
    Ray geckoeng
