R8 brake booster
Results 1 to 18 of 18
    Member starkzmi16's Avatar
    Jul 2005
    45
    Default R8 brake booster
    Hi guys,
    Recently bought myself an r8 and it has a problem with the brakes gradually building up brake pressure and the pedal goes hard. It has a pbr vh44 remote brake booster and to release the pressure I am having to crack the bleed nipple at the booster. I have tried running it without the vacuum line and no difference. I have also adjusted the free play at the pedal with no difference. So my next thought was replacing the brake booster, but I am unsure if I need the vh44 or vh40, everything that I have read says the 44 is for drum brakes. So was chasing people's opinions.
    Cheers Rory
    Fellow Frogger! alpinesau's Avatar
    296
    Rory,
    I have a VH44 on my R8 Gordini. It has been on there for over 30 years without an issue.
    Robert
    1970 R8 Gordini R1135
    2005 Megane 225 Cup
    2008 Clio X85 Cup Racer
    2014 Megane RS275 Trophy R
    2015 Koleos Expression
    Sep 2004
    Tamworth UK
    624
    My gut feeling will be the many times mentioned internally collapsing flexi brake hose somewhere in the system. Back to basics.
    Fellow Frogger! bingham driver's Avatar
    Jan 2011
    Myers Flat
    182
    Try cracking the pipe from the master cyl to the booster, if that releases brakes its the master cyl.
    Otherwise its probably the booster cylinder(swollen rubbers).
    Once I thought I was wrong but, I was mistaken
    11,294
    Quote Originally Posted by starkzmi16 View Post
    Hi guys,
    Cheers Rory
    I won't add to the advice already given as that's what I'd do too. Is it the lovely dark green one with big headlamps and with a tacho in the right hand dash vent? Not many R8s have boosters added.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Perth Western Australia
    2,705
    Rory,
    Could there be a residual line pressure valve in the master cyl or the booster hydraulics? Something I've understood is that fully disc brake systems don't require these. Anyone?
    Faulty brake compensator, if fitted ?
    Jul 2005
    45
    Thanks for the advice guys tomorrow I will pull down the original master cylinder and give it a clean up. As for the residual pressure valve I am not sure. I have recently bought this car but the brake booster was fitted se time ok and I am assuming the brakes were working correctly at some stage in this cars life. And no the car is blue not dark green.
    11,294
    Rory,
    Interesting thought. There are two types of fitting inside those R8/R10/Dauphine/4CV master cylinders, one of which is for drum brakes (yes, non return) and one that allows movement of fluid both ways. Heaven knows what might be in the MC or the booster in that department.
    As a rule, you really don't need a booster on an R8. Go for the smallest diameter master cylinder (19 mm) and make sure the calliper pistons are not seized and they are pretty light.
    Simon's Avatar
    6,203
    If cracking the bleed nipple releases the brakes, it sounds more brake servo (and backwards to the M/C) related rather than calipers, brake hoses and pressure limiter related. Try as Mr Bingham driver suggests, to isolate the problem to the servo or M/C.
    Then again, if the car is a new acquisition with an unknown history, it wouldn't do any harm to just replace all the wearable things in the brakes, seals, etc, and overhaul the servo.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    Burswood Western Australia
    428
    Renault 8 must NOT have a residual pressure 'foot Valve' in the Master Cylinder ( if it has then brakes will not fully release and will drag/ overheat. If brake pedal is progressively building up pressure, so that pedal becomes increasingly hard with no free travel it is USUALLY insufficient free play between brake pedal and master cylinder push rod...try slackening off the free play on push rod, at pedal end.
    4,425
    Quote Originally Posted by Rod Slater View Post
    That could be a real cheap fix if it is that!
    KB
    Boonah Qld
    2,632
    If drum brakes need a "foot valve" and disc brakes don't then what about a drum/disc combination?
    Jan 2011
    Myers Flat
    182
    The residual pressure valve(usually 7lb) is to stop wheel cyl cups from collapsing, causing leakage.
    This minor pressure is normally not enough to overcome caliper piston seal resistance.
    Excess pressure build up is usually caused by cup swell blocking the hole to/from the reservoir/supply pipe, stopping the fluid getting back
    thru the system when you release the pedal.
    Jan 2011
    Myers Flat
    182
    Same symptom as no pedal clearance!
    Newcastle
    2,797
    Default ??
    Quote Originally Posted by bingham driver View Post
    Hi,
    I have experienced this pressure build up twice when the fluid supply hole became blocked by corrosion/sh*t. On a trailer and a motorcycle. The brake drag heats the fluid at the wheels and it cannot return to the reservoir, just the same as the case of insuficient adjustment, cup swell etc. Wheel lockup both times. Front wheel on the bike and threw me off unexpectedly and in no time. However both times the vehicles were unused for quite a while before the incidents.
    jaahn
    Member Pepster's Avatar
    Feb 2013
    Westmeadows, Melbourne
    61
    I just saw this thread (a month late).
    Rory, you need to attend to this without delay! I had a similar problem with my R8G many years ago, where the brakes were getting more and more sensitive. So I decided to keep drive a bit more carefully and keep an eye on it. Bad move!
    One day while slowing down on a multi-lane road, the brakes locked up without warning. The car stopped almost instantly in the middle of the road, resulting in a collision between two other vehicles behind. So there I was in a panic, reaching under the car with a spanner to release the bleed nipple. Another bad move, because as soon as the fluid spurted out, the car started rolling. Could have easily lost my arm. Chased the car, jumped in and stopped it. Very embarrassing!
    Something in the booster was worn, but I'm not sure what. I won't be doing that again!
    Peter
    1968 R8G 1300
    1965 R8G 1100
    1972 R12G
    1978 Virage
    1977 R12XL
    1971 R10
    1968 R10
    Feb 2013
    61
    And while we are on the subject, does anyone know the correct VH booster for an R8G? I see many references to the VH44, but when speaking to Hydroboost recently, Terry mentioned the VH44J. So I'm a little confused.
    Peter
    1968 R8G 1300
    1965 R8G 1100
    1972 R12G
    1978 Virage
    1977 R12XL
    1971 R10
    1968 R10
    Jul 2005
    45
    Have sorted the brakes out now, was the master cylinder. I bought a new one from mecaparts and re bled the system and now the brakes work very well.
