2002 Scenic running rough...
Results 1 to 8 of 8
    Jan 2013
    3
    Default 2002 Scenic running rough...
    I have a 2002 Renault Scenic that is running rough. It coughs and splutters and loses power when driving. Yesterday I washed the car and used the hose to clear out some leaves in the engine bay, the problem started immediately after...
    I just took it for a run then, same thing, at idle it sounds like an old veedub with that distinctive popping, then when driving will lose power like its misfiring when accelerating. will run smooth then start up rough again.
    Wife's car and I'm not going to hear the end of it if its something major.
    Should get a life 2353's Avatar
    Brisvegas
    4,049
    Did you get some water in the electrics?
    Save the earth, it's the only planet with chocolate.
    Jan 2013
    3
    Could have... but not sure where to start looking at that or if I should...
    Oct 2005
    North of Hornsby
    2,664
    Sounds like coil packs and/or water in the plug wells. In the latter, push some paper towels down the plug wells (after removing the coils) to absorb the water and if necessary remove the plugs and give them a clean. Any residual water will drain onto the piston crowns and will be dealt with smartly after you fire it up. Some WD40 will displace residual water.
    If you find the plug wells are full of oil it means oil is leaking from the cambox seals. It costs a lot of money (in labour) to repair so you can get a six month fix by simply mopping up the oil and cleaning the plugs (just like you did with the water). More smoke upon start up with oil though... In six months you can repeat the process...
    Common enough problem on the K engines.
    Dave
    2008 Renault Laguna 2.0 dCi estate
    2013 Renault Koleos 2.0 dCi 4WD
    ​1997 BMW K1200RS
    IR655
    1000+ Posts driven's Avatar
    Apr 2005
    1,573
    Try leaving the car out in the sun with bonnet open, may dry things out
    Jan 2013
    3
    The prize goes to....68 404!
    So I took out the coils and sure enough there was water in to of the plug wells, wasn't able to remove the plugs (didn't have a long enough socket extension) but packed in some chux and tamped down with a skewer and put the coils back in..voila! Car starts and run smoothly enough, a bit of residual murmur so the plugs might need replacing at the service later this month...
    Thanks everyone
    BTW I found this youtube clip as a bit of a tutorialhttp://www.youtube.com/watch?v=jnXhjPKIahI
    11,310
    Quote Originally Posted by markle View Post
    Thanks everyone
    I was laughing at the thought of leaving a car outside in Melbourne to dry but I guess this month that would work! Good it is fixed.
    And of course a "residual murmur" is the sort of thing that might have been there before but up until then you had no reason to listen carefully for it.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Oct 2005
    North of Hornsby
    2,664
    Thanks everyone
    Great that it was an easy fix and thanks for the courtesy of acknowledgement!
    If you buy a cheap 1/4" socket set you will find you can access the plugs. 3/8 ones are too big (as you have found out).
    Cheers, Dave
    ​1997 BMW K1200RS
    IR655
