Suddenly a really loud bad rattle
Results 1 to 25 of 29
    Mar 2011
    Geelong Victoria Australia
    13
    Default Suddenly a really loud bad rattle
    Scenic Megane
    It came on very suddenly and it sounds like the car is shaking itself to pieces, but it still tracks straight and rides as well (Or as badly ) as ever and when braking it is as straight as ever and as quick. I put the car up on a jack and I can see no obvious loose bits or missing screws/bolts etc but I did see that the plastic boot on the RH rear shocker has come adrift. Could a small plastic boot be causing so much noise? and if so do we need to replace the rear shocks?
    car has only done 60k but is 6 years old now Timing belt was replaced as per service intervals and has always been book serviced
    needs new tyres as well,
    8,257
    Quote Originally Posted by Moondog55 View Post
    Scenic Megane
    You don't indicate where the noise is coming from, front, rear, under-bonnet etc.
    A new loud rattle noise? Could be dual mass flywheel, or crankshaft pulley (harmonic balancer) if the noise is engine related.
    Crankshaft pulley can be checked by marking through the diameter with something like a white-out pen, running the engine and check for movement between the inner and outer.
    Others more familiar with the Megane will no doubt offer other possibilities
    08 C5 X7 HDi very Noir
    4,425
    I'd also look at engine mounts.
    The megane has a reputation for going through them.
    KB
    Mar 2011
    13
    Sorry
    RH rear in or close to the wheel well
    Sounds more like a plastic component than engine or drive train, it isn't the exhaust or the catalytic converter to the best of my limited knowledge.
    I just took it for a drive around one of our really rough roads ( not hard to find in Norlane) and it did feel like it was bottoming out on a couple of potholes
    Should get a life 2353's Avatar
    Brisvegas
    4,049
    If it's coming from the rear and since the bang there is a "loose muffler/exhaust" sound while turning, going over driveways etc - check the rear axle. Our 07 Grand Scenic with a tad over 50k on the car has been in a dealers yard since the week before Christmas waiting for a new axle to get here from France.
    Save the earth, it's the only planet with chocolate.
    Fellow Frogger! Trading Estate's Avatar
    587
    try this first
    Earlier Scenics had faulty batch of shockers that come adrift from their mounts. Common problem google 'shockers mounts scenic'.
    The weld breaks and they rattle and clang until you replace it ! Sounds like right rear shocker?
    '04 Megane
    Gone but not forgotten
    '71 16 TS, '72 16 TL, '74 15TS,'82 20TS Series 2, '85 25 GTX. '49 L15,
    Mar 2011
    13
    Sounds like the shocker has gone then> I wonder why it did not rattle and come loose in my hand when I checked under the car?
    Where would fellow members recommend shopping for a pair of replacements? It seems like they OEM were very shoddy part but 5 years and 60 ks is reasonable I guess
    We don't have an owners repair manual, whats the easiest way to remove these buggers? I can't see the top of the shockers how far off the ground do I need to lift this thing??
    Wifes car, I'm a Toyota' / Ford bloke myself
    Thanx for the help so far
    1000+ Posts Europa's Avatar
    Jan 2002
    2,432
    Attached doco may help, assuming I have the correct model Scenic...
    Attached Files Attached Files
    Mar 2011
    13
    Thanks Europa but that doesn't look like the beloveds car
    Torsion bar rear suspension on hers and there is nothing in the rear that looks like a bolt The bolt may come into the storage compartment under the seats I'll pull the rear seats off the mounts ( that is one thing Renault got right) and have a look there.
    Cecile really likes this car and we need to keep it until we finish the house renovations
    Mar 2011
    13
    And I find the cheapest shockers are the dealer replacement at $196 a pair, that's a few dollars cheaper than bring in aftermarket ones from the UK or France and I really do not think the vehicles needs Bilstein or Koni aftermarket types after all we are not racing and our roads don't allow us to use anywhere near the speed these cars are capable of
    Member Freddie's Avatar
    Apr 2002
    Torquay, Victoria
    72
    sounds like Rr shocker upper mounting - you will not feel much play even "off load" but they make an awful banging noise
    Had our Scenic's go as well - best buy was French Connection (Dave - sponsors this site) - had a pair delivered to Torquay within 2 days - I remember Norlane Rds (probably same still as in '60's)
    Suggest you retain a matching pair/axle
    Mar 2011
    13
    The most appreciative of thanx Freddie, wonder of wonders he has a set waiting to be taken out if I can't pick them up tomorrow I'll get them posted to us down here. Roads are much worse in some places than they were and some are remarkably good
    Jan 2002
    2,432
    OK try this one (older model Scenic)
    Mar 2011
    13
    Thanx Europa, I had to wait until we could use Ceciles computer to unzip that file, piece of cake, I was looking for a nut and bolt that obviously wasnt there, it is of course a 2002 model and CC just reminded me that the car has done over 80k
    Aug 2011
    Australia
    16
    It's a Scenic Dynamique, and has actually done 120k. These are the original shockers.
    Truth is, things that you would consider normal wear and tear on an 11 year old car are all going at once. It needs a brake booster replaced, work on the transmission. Finding a company who is truly interested in doing the brake booster particularly is turning out to be a nightmare. The dealer wants close to $1k to do it and the local euro repair shop has failed to get back to me after repeated requests for an estimate.
    Car overall is in OK condition for its age, and no rust (although there are a few very minor dings). Now trying to work out whether or not it's feasible to spend 3k on repairs.
    Thank you all for an informative and helpful forum.
    Oct 2005
    vic
    868
    Re - booster - take it to a brake place.
    I use a place called Superstop for parts, havent actually had work done by them, but assume they do.
    The hard thing will be to get it out.
    If you can do it yourself, then obviously you will save $100's.
    I would be very surprised if they were not rebuidable - most are, they just need a diaphram.
    David
    Mar 2011
    Linton.Victoria.
    1,280
    Hi-I have heard of this problem before-Wondering if it is possible to re-weld same-Sounds a bit like the batch of Commondores years ago that missed out on half of its welds.
    Pekay.
    Member markb2501's Avatar
    Croydon NSW
    102
    Hi Cecile,
    After my wife took our 01 Scenic on fire trails around Kangaroo Valley a year ago, similar story. Diagnosed as a broken rear shockie. It's really very simple to do (I am a pen pusher and I did it in under 20 minutes!):
    1. Obtain rear shocks (I popped one in from the wreckers - $40, bargain from what I can see compared to new. Should it last 2 years I have made up for the extra $$ I didn't have to spend).
    2. Whilst vehicle on ground, loosen lower end bolt a tad.
    3. Jack car up enough and remove rear wheel.
    4. The shockie goes at about a 45 deg angle towards the front of the car - slightly peel back the dirt/rubbish protector thingie at the front end where the shockie starts to disappear. You will find the top bolt there.
    5. Remove both bolts, remove old shockie, insert new shockie.
    6. Replace both bolts, tighten accordingly.
    7. Replace wheel and let the car back to the ground.
    Hoping this helps you mate....
    Mark
    Aug 2011
    Australia
    16
    Quote Originally Posted by 85Fuego View Post
    David
    Thanks for your information re booster. I took it to a franchise brake place when it first started happening (5 years ago!) and the moron could not even FIND the booster. There is a Euro repair shop here in Geelong, who was meant to give me an estimate to replace with a second hand unit but they have not called me back after several enquiries...obviously they don't want the job because it's fiddly and a pain in the proverbial to get the thing out. I have heard that there is a pressure relief valve on the booster that is causing the hissing noise that comes from behind the brake pedal, but evidently there are no parts available for this.
    More and more I am wondering whether it's actually feasible to repair the car...the work needed all up is close to the current market value. Unfortunately I'm not in a position to replace it at the moment, or I would.
    Oct 2005
    vic
    868
    Replacing boosters with an unknown second hand unit with say 3mths warranty, to me, seems crazy. They all age at the same rate (plastics).
    If you are going to take it out - get it recoed. The labour is the expensive bit - not the parts - do the job once.
    The internals are usually common to more than one make, so parts 'should' not be a problem.
    My Fuego was rebuilt for under $200.
    Keep looking there's more than one brake place.
    Don't go to euro specific repair places if you can help it - they will sub out to brake places anyway.
    I would get quotes from Melb, and, if needed drop it off if it means less $$$.
    My worth.
    1000+ Posts Haakon's Avatar
    May 2002
    canberra...
    8,876
    Booster failures are bloody rare, even in old cars... Never come across one myself thats for sure.
    I would not hesitate to put a s/h one in if thats really what was wrong.
    Boonah Qld
    2,632
    I had never had a booster go until 2012. Both R15 and R17TS boosters stopped working. I had a spare for the R17TS but the R15 one is listed for repair, I hope.
    Oct 2005
    vic
    868
    I had 2 cars, 2 different makes, 2 boosters requiring rebuilds, not as uncommon as you think.
    Was just saying, if it were me, and the booster apparently took that long to take out, why would you put an unknown quantity back in?
    Aug 2011
    Australia
    16
    Default Definitely a broken shocker!
    The weld has broken off at the top. The dealer will have the new ones in tomorrow morning.
    What was insanely annoying is that these shocks are quite specific, and six phone calls to local specialists failed to locate suitable units. Even the dealer had to get them in from the Sydney warehouse.
    Re the brake booster, so far I have been estimated about six hours to do the work, plus the price of reco unit. Thankfully it's not an urgent repair.
    Thank you to everyone here who offered suggestions and assistance.
    Attached Thumbnails Attached Thumbnails Suddenly a really loud bad rattle-img_5044.jpg
    Mar 2011
    13
    Just took off the RR shocker, as per usual it took me longer to find the tool ( 21mm Socket spanner) than to do the removal and that includes jacking up and taking the wheel off.
    As stated "Piece of cake"
