renault 12tl speedo
    Fellow Frogger! le frogg 205's Avatar
    canberra city australia
    394
    Default renault 12tl speedo
    hi every ones happy neew year .have got a litle problem in my renault 12tl (1974} have got a vdo speedo/tacho ,and the speedo cable is missing ! the dash bord id a part for re triming .the tacho was connected but not working i run a wire from the coil to hit and voila !.. but the speedo need a cable with a big nuts if you know wat i mind .the jeager is way to small.any idea ? i think it is not the original cluster .but from witch car ?
    Simon's Avatar
    6,203
    If it is a post 6/1974 (up to 1/1975) compliance date R1170 on the oval plate (a 12 TL) it would be a replacement VDO cluster, if it is a post 6/1974 (up to 1/1975) R1177 model (12GL) the VDO speedo/tacho cluster was standard.
    For a VDO speedo cable, try the usual suspects at French Connection or Caravelle Imports, and if no joy, then try the wanted column or Pick-A-Part wreckers for a 12 with a VDO cable.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,331
    Le Frogg205
    I have VDO speedo cables, they are second hand. If you are not in a hurry and can wait I can post one to you.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    394
    ok just waiting a guy here said i can change the end of the jaeger i give him.to a vdo ! cross fingers if not good i get one of yours.i also have to find where is the conection on the gear box
    thanks.
