Laguna II V6 2002, ball bearing found in undertray to engine bay ?
Results 1 to 15 of 15
    Oct 2002
    Melbourne Victoria
    12,663
    Icon5 Laguna II V6 2002, ball bearing found in undertray to engine bay ?
    Today I set about retrieving an 8mm bolt that had dropped from the engine and lodged in the plastic undertray of the Laguna engine bay. I found the bolt o.k. but also found this rather large ballbearing also sitting in the tray.
    I cannot figure out where the ballbearing might have come from. Its about the size of an indent ball that retains a moving shaft in predetermined location by pressure on a matching vee in the shaft. I can't see any likely candidate or mechanism that it could have fallen from. The Laguna has an auto transmission.
    If anyone has knowledge of such a ballbearing being used on the Laguna engine, or any idea where it might come from and whether it lying loose in the engine bay might have some critical effect on the engine operation.
    I don't see anything that might correspond or relate to its use. I would appreciate any advice as to its possible use etc.
    Ken
    Laguna II V6 2002, ball bearing found in undertray to engine bay ?-laguna-spare-ball-bearing.jpg
    Burswood Western Australia
    428
    Sorry, got me stumped?
    Oct 2002
    Melbourne Victoria
    12,663
    Thanks for the quick reply Rod.
    Fellow Frogger! Rally's Avatar
    Pearl Beach NSW
    562
    It may have been droped by someone blocking off vacume hoses , easier to get another ball then to find the droped ball.
    Peugeot 504 Rally car V6
    Peugeot 504 LTI
    Peugeot 504 Ti
    Citroen SM
    Citroen Light 15
    Peugeot 406 SV 5 speed
    Citroen DS23 EFi Safari
    Toyota Land Criuser V8 Super charged ( to tow the rally car )
    Rally with www.AMSAG.com.au
    Perth Western Australia
    2,705
    Ken,
    If all systems, gear selection etc are OK Forget it. Nothing to do with the 8mm bolt ?
    Oct 2002
    Melbourne Victoria
    12,663
    Ken,
    No WB, I changed a front coil and the 8mm bolt that secures it flipped out, and dropped down the bonnet catch hole, At the time (murphys law!!) I was unable to retrieve it due to time constraints and restricted movement after an operation, so just found another that would fit the newly fitted coil as one of those temporary measures.
    Hex bolt head of course was a different size - hence the eventual search for the original!! fortunately it was still there in the tray.
    The other was just a "ballsup" at least I hope that is so!
    Regards, thanks for the replies.
    Ken.
    11,305
    Could have been there for years! I just found my favourite 8-10 mm ring spanner sitting on a wheel cylinder bleed nipple. It must have been there for a full year.
    Is there the slightest chance that it was flicked up from the road?
    Do you have a spare steering wheel for Geckoeng?
    Best wishes for 2013.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Simon's Avatar
    6,203
    What work has been done to the car since the undertray was last removed? List all the tasks, eliminate the obvious ones, then see if any of the leftovers involved, or may have involved, the removal of a bearing.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    Don't remind me!
    16,609
    It's the sealing ball from the pressure regulator - someone has opened the bleed screw right out when depressurising the hydraulics, then refitted it without recovering the ball.
    3,654
    Maybe it was put there just to confuse you
    .2010 Holden Commodore Ute
    428
    Could it be the 'indent' ball from a socket extension?
    Oct 2002
    Melbourne Victoria
    12,663
    I would hope not Addo...hydraulics are working o.k. and the last time it was worked on was during the top up and servicing of the automatic transmission, but I would think that service would have involved the removal of the undertray. I'll check with the garage that did the work. No bearing work done in recent times.
    I am in the process of arranging the use of a car hoist at a local garage, as I miss the opportunity to walk around under the car and do my own inspection. Max Kirwan offered me free access to their workshops on weekends to work on all my cars at one time, and I regret not taking him up on the offer.
    Ken
    bob
    bob is offline
    May 2001
    Skipton
    2,538
    G'day Ken,
    aaargh, the tray, useful animal for catching all that stuff that leaves the butterfingers instead of getting lost in the grass. The r20 had one, grotty place to retrieve from though.
    None on the Fug, is that normal ?
    cheers,
    Bob
    Oct 2002
    Melbourne Victoria
    12,663
    Quote Originally Posted by bob View Post
    G'day Ken,
    cheers,
    Bob
    Engine undertrays were fitted in the colder Northern Hemisphere, I presume that the importers removed them to get better air flow as on at least one of my fuegos I notice the screwed captive nuts are there to secure a tray in position.. or perhaps it was an economy measure ?
    Ken
    Oct 2002
    Melbourne Victoria
    12,663
    Quote Originally Posted by Rod Slater View Post
    Checked on my socket extensions etc and it is "possible" though by sight the "found" ball looks slightly larger than those in the sidchrome tools that I have. (none missing as far as I can tell Rod!!
    Ken
