Hot wire a Scenic?
Results 1 to 14 of 14
    Feb 2001
    Romsey, Victoria, Australia
    4,904
    Default Hot wire a Scenic?
    Does anyone know if its possible to hot wire a scenic to by pass the immobilizer?
    Problem we have is an RX4 thats been sitting in a paddock for 12 months.
    With a fresh battery its cranking over but wont start, we can hot wire the fuel pump, thats easy but getting power to the ignition is a hard.
    It seems that wilst sitting its forgotten how to start, no power to the pump or ignition.
    Its only a wreck, we just want to start it to get it down to Melbourne so we can dismantle it, we need to know how good the gearbox feels before we can offer any kind of warranty.
    I know we can change ECU/BSi key reader but its a bit of work just to get it here to strip it so hoping someone knows a cheat. Being a wreck we have no fear of cutting and rewiring anything.
    Yes, we have pressed the fuel pump reset button before any one suggests that.
    David Cavanagh
    03 9338 8191 or 03 93354008
    34 KING St
    AIRPORT WEST
    VIC 3042
    frenchconnect@bigpond.com
    1000+ Posts Haakon's Avatar
    May 2002
    canberra...
    8,876
    Cant be done AFAIK. You'll need to take donor ECU, BSI and key remote and install... 2WD Scenic items might work?
    1000+ Posts Fordman's Avatar
    May 2004
    Perth/West Australia
    1,535
    It has been said elsewhere that the main ECU connector pins can be subject to corrosion, etc. Have you tried just removing the connectors and spraying them or whatever. It may have bad connections.
    No expert, but I cant see why being unused for 12 months would lose the main memory in the ECU - could be wrong though.
    The older cars had a fairly standard immobiliser over-ride of turning on ignition for 30 minutes which allowed starting. After turning off it would require the same procedure every time until fixed. About 1998 IIRC this was disallowed in the immobiliser standards so no over-ride was possible. However what they did in French cars I don't know.
    When I puchased our Scenic (Jan 2004) I requested immobiliser over-ride code for my car, but the dealer claimed there was not one - it had to be connected to the Renault dealer "computer", ie, a tow job from anywhere in the state.
    Cheers.
    Last edited by Fordman; 14th November 2012 at 11:40 AM. Reason: added more useless information
    2004 Scenic I 2.0 auto (Hers)
    2016 Ford Territory (His)
    2004 WRX (Sunday car)
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,336
    Hi Dave
    Not sure about the Scenics but my Laguna starts the stops 2 seconds later if the car is immobilised (that is you need lock the car and unlock with the plip). Mine is a 1995 series 1
    Also if battery is flat in the plip you are stranded until you get a new battery.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Feb 2001
    4,904
    Hi Dave
    Thats right, my wifes car is the same but Scenic is a different animal.
    I'm just trying to avoid changing the cars brains over in the peoples front yard in central Victoria but its looking like we don't have a choice.
    David Cavanagh
    34 KING St
    AIRPORT WEST
    VIC 3042
    Jerangle
    812
    David,
    i found a site in the UK which gives the re-set procedures for most recent cars.
    Can't find it now but will look.
    Berridale
    8,484
    I dont think thats the case with the laguna1
    I seem to vaguely remember a procedure with the accelerator pedal and computer toggle stalk whereby you could manually input the code.
    Might be written in the handbook, which I sold with the car.
    Talk about high security, the dealer gave me the code over the phone..
    Jo
    4,425
    I'm pretty sure on my old Laguna, the manual said if the battery in the key card won't unlock it just use the manual key, stick the card in the reader and it should still start. But that is a different problem to Dave's I think.
    KB
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,336
    Jo
    Don't remember that in the owners hand book Jo
    Regards Col
    1973 Alpine A110
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,336
    I think that is the case with the Laguna 2
    Regards Col
    1973 Alpine A110
    8,484
    Ah it must be secret renault information.
    That info could probably be worth about $370+ gst to a dealer.
    jo
    Feb 2001
    4,904
    Well we changed the ECU, BSi, key reader and key fob thingy all from a car we drove into the yard and still nothing. No spark, no fuel.
    So we gave up and trailered it in behind the mighty 406.
    David Cavanagh
    34 KING St
    AIRPORT WEST
    VIC 3042
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,336
    Quote Originally Posted by David Cavanagh View Post
    Dave
    Its obviously non of the above that is causing the problem. Maybe its the fuel relay or something similar or even a wiring problem somewhere.
    Regards Col
    1973 Alpine A110
    Feb 2001
    4,904
    Dave
    Dunno, give up, its here now and the gearbox is already sold so its going on the hoist now to be dismantled.
    This car drove home after hitting the roo but has been sitting for 12 months with the battery still conected so maybe thats how it got infected (Do they have a shelf life?), the battery was flat as a tack, but the doner "brain" has been sitting on the shelf with no power for about the same time, it came from a working car so it should still be fine so don't know what the problem is, don't really care anymore, its about to be chopped up.
    David Cavanagh
    34 KING St
    AIRPORT WEST
    VIC 3042
