Dauphine piston/ liner copper seals
Results 1 to 25 of 25
    Member 61 Gordini's Avatar
    May 2012
    Torquay
    77
    Default Dauphine piston/ liner copper seals
    Hi,
    Does anyone know where to buy the copper seals for the liners in dauphine engines.
    It's how I roll...Brisbane
    33,949
    Every day when I wake up I reach up in the darkness with my eyes shut and if I cannot feel anything that resembles a wooden lid I know it will be a good day. No lid today.
    11,299
    Quote Originally Posted by 61 Gordini View Post
    Hi,
    If Dave doesn't have them, there's Caravelle in Melbourne. I guess Auto Paris/France.
    But then go to France on line - Melun Retro Passion for example (and Web Pieces Retro has them in stock - I just checked). http://www.web-pieces-retro.fr/PEEL/...id=18&start=10
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Feb 2005
    rosevale/tasmania
    2,872
    Incidentally, if searching on Ebay France (not Ebay Australia with International setting) your search term will be:
    'Joints d'embase cuivre' -that is: copper base gaskets. Maybe also include 'chemises' (sleeves) & remember that 'R4' is as good as 'Dauphine'.
    And for talking with the seller, Google Translate is good enough.
    If you want an English speaker & none of the locals have the bits, then Jacques at Rear Engined Renault Parts in the States is reliable & friendly.
    Peter
    May 2012
    Torquay
    77
    Thankyou Every one for the help.This is my first time on aussie frogs.Now i can start to collect the parts to rebuild my engine.it is the original engine from new.Not bad for 51 years.
    Brett
    1000+ Posts J-man's Avatar
    Littlehampton, S.A.
    23,619
    Welcome to AF 61 Gordini, and please feel free to post some pics of your Gordini project
    cheers,
    John
    Apr 2004
    Western Australia
    238
    Default Dauphine gordini Bits
    Hello , I have some new and used bits for Dauphine Gordinis PM if there is anything you may want .I have a range of of bearing shells and a good condition used cylinder head amongst all the bit and pieces.
    Ici.
    2,667
    Will paper ones not work?
    Jan 2011
    Long Beach NSW Australia
    73
    You could also try Jacques Rear Engine Renault Parts in the States, great bloke to deal with.
    11,299
    No. Ventoux engines all used copper, much thicker AFAIK.
    Boonah Qld
    2,632
    If the original ones are not damaged heat to blood red and let cool and reuse them.
    Boonah Qld
    2,632
    I should have added make sure you have the proper protrusion you might be lucky enough. You can also cool in water. Unlike steel copper softens when cooled.
    11,299
    Hi,
    The whole point, just to be clear, is that the liner seals also provide enough thickness for the liners to protrude slightly above the level of the block by, if I recall, 2 to 5 thou. These clearances need to be roughly even and make sure the head gasket seals properly around the sleeves as well as holding them down tightly enough to seal. This also makes the straightness of the head itself critical. Also check carefully that the block is straight (they almost always are fine).
    May 2012
    Torquay
    77
    Thanks for that info, John, the engine has a very hot cam with head & cam follower mods , so any info is much appreciated.
    Brett
    11,299
    Brett
    Hi Brett,
    Are you a member of the Renault 4CV Register of Australia? Lots of folk around to help and advise.
    Which Torquay are you in?
    May 2012
    Torquay
    77
    Torquay Vic.
    No I am not but I know a guy who is.I sold him a white Fluoride and he has a or did red 750,I can't remember his name.i think he was the president at one time.My car has gordini on the no plate
    11,299
    Torquay Vic.
    Ah. Here's the link for you. http://www.4cvregisteraustralia.org/
    Great group to join.
    Simon's Avatar
    6,203
    For the R4 only.
    No, the paper gasket liners and seals won't suit the late model (1969) R4 blocks. According to the good 'ol MR61, the R4 block was changed on 20/12/1968 to use paper liner seals. You can use the old copper seal liners and liner seals with the late model block, but you can't use the later liners and paper seals in the earlier block. The late block can be identified by having the drain plug change location from the timing cover end of the motor, to the side of the block under the manifold.
    However it would be similar for the Dauphine, the later paper seal liners won't suit the Dauphine block.
    Also note that there are three types of copper liner seals: 0.95mm, 1.0mm & 1.05mm.
    Also from the useless info file. If buying pistons and liners, not only check the liners are for a copper gasket block, but also that the gudgeon pins are 14mm, and not the later 16mm interference fit gudgeon pins. Of course, if the Dauphine has a modded motor, it may have alternate custom modifications.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    Simon's Avatar
    6,203
    That plate, and if it is the red car in your pic, looks like the ex-Bruce Porter car from SA.
    1963 Renault R4 Van
    1964 Renault R4
    May 2012
    Torquay
    77
    Yes it is,i bought it from his brother Russell in 1991 who had it shipped over to Melbourne after Bruce Passed Away.
    11,299
    Excellent. Well done Simon!
    I remember that car when Bruce had it. Same colour as my R8.
    I have this vague memory of making contact with you in the mid- to late 1990s in that case.
    May 2012
    Torquay
    77
    The car went to its 1st French car day in 1999.A tall slim man walked up to me and asked if it was Bruce Porter's car from S.A as he recognised the sticker on the windscreen.could that have been you John ?
    Littlehampton, S.A.
    23,619
    While we're revisiting red Dauphines from the past, does anyone know who owns this little gem ?
    Dauphine piston/ liner copper seals-afcd9.jpg
    cheers,
    John
    11,299
    Not I. Haven't managed to be interstate (from Perth) for a FCD for years.
    A red 4CV and President of the Register some years ago sounds like George Cook, then living near Captain's Flat or Canberra. But there are a few red ones around at the core of the Register.
    Good luck with the rebuild. Straightforward if care is taken.
    May 2012
    Torquay
    77
    I saw that car at the Renault Round up in Melbourne this year but don't know who owns it
