Fuego carby on 2.2 engine
    Dec 2002
    2,528
    Default Fuego carby on 2.2 engine
    G'day Renophiles!
    It's not going into a Renault, but I've got a 2.2 litre Douvrin from a Peugeot 505 that I'm putting in my 403. Does anyone know if it will run OK with a standard Fuego carby, without any rejetting? I'm not after power, just something that runs smoothly with no flatspots. It will be auto.
    The standard 505 STi cam that it has is fairly tame, and I believe it is softer than the Fuego cam, so that shouldn't really cause a problem.
    Has anyone run a 'big block' fuego with standard fueling?
    Scotty
    Melbourne - Dandenong Ranges
    2014 Peugeot RCZ - 'Remy'
    bob
    bob is offline
    May 2001
    Skipton
    2,381
    G'day,
    probably will run OK, but there was a version of the 2.2 with a weber according to Mr Haynes....
    cheers,
    Bob
    Attached Thumbnails Attached Thumbnails Fuego carby on 2.2 engine-haynes1784-043.jpg   Fuego carby on 2.2 engine-haynes1784-044.jpg
    Simon's Avatar
    6,161
    How about looking for Weber from a XF Falcon or 20TS Automatic? They will also have the linkage for kickdown cables.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    9,181
    You will need to dry sump the engine, gets a bit pricey with pumps etc.
    Also it is essential to use the proper engine mounts, a lot of vibration otherwise.
    Much easier fitting an L series Datsun and really not much less authentic.
    Graham
    Quote Originally Posted by Demannu View Post
    G'day Renophiles!
    Canberra ACT
    681
    G'day Renophiles!
    I have previouslyinstalled a 2.2 litre motor from a Renault 25 in one of my Fuegos some time ago and it run great with the standard Weber Carbie. Only issue was the engine sat slighly higher with the carbie cover just touching the inside of the bonnet.
    bazzamac
