al4/dh0 question
Results 1 to 24 of 24
    Fellow Frogger! ving's Avatar
    Aug 2012
    campbelltown
    223
    Default al4/dh0 question
    yes i am still experiencing problems with my "auto" light.
    my question is: what of the transmission is engaged while the car is in park?
    reason: the auto light came on soon after the car was turned on and still in park. upon this occurrence there was a strange sound (whirring?) in the engine bay. of course i turned her off and restarted.
    any clues?
    Current frogmobile: '02 Renault Clio Expression.
    Previous frogmobile: '85 Citroen BX16 Trs.
    1000+ Posts Haakon's Avatar
    May 2002
    canberra...
    8,752
    Oil pump... Whats the code thrown?
    Don't remind me!
    16,609
    Has the gearbox had its solenoids done and a software update?
    What about oil level checked? Start with the basics.
    Aug 2012
    campbelltown
    223
    Default Re: al4/dh0 question
    Yup very recent. Also inhibitor switch.
    Oil pump. Hmm...
    Don't remind me!
    16,609
    I'd be surprised if it were the oil pump.
    The fault readings are of interest.
    Aug 2012
    campbelltown
    223
    fault readings have thus far lead down the road of replacing parts that dont need replacing... just after ideas. last code btw was speed sensor
    Don't remind me!
    16,609
    Output speed sensor?
    Inductive sensors are easily tested, line pressures can be tested externally. It's rare for these items to fail, and I am concerned you paid for stuff that should have been more fully tested.
    Have you heard the noise made by actuation of the electrovalves? It's quite strong.
    http://www.audiocheck.net/audiofrequ...squaretone.php - select a 100Hz square wave of five seconds or so duration; open the file (not save). (You can also listen to a 50Hz one, to make sure the software was upgraded.)
    Relevant, too, is alternator output quality (the beginnings of failure may include obstructive waveforms) and overall underbonnet connectivity. See recent posts by "shanadoo" for this detail as found on PSA cars. I am not familiar with the Renault fuse/relay panel but it's unlikely to be from another planet.
    Aug 2012
    campbelltown
    223
    Yup the software was def upgraded. As for the rest of what you said, its all Greek to me.
    Would poor alternator output create a situatio where the auto light would come on?
    Yes I think I paid for repairs that didn't solve the problem. Seeing that a code came up for a short to pressure solenoid. Maybe there is an electric short somewhere from said solenoid back...?
    Thinking of getting electrics checked by an auto electrician.
    Aug 2012
    campbelltown
    223
    The fuse/relay panel, that's the one in the engine bay not the regular fuse box hey?
    May 2002
    canberra...
    8,752
    I have the same short to positive faults on my AL4, and they're false.
    You can check this with a multimeter across terminals at the ecu plug, noting the resistance.
    I think its software phantoms. Nothing you can do except replace the ecu - it cant be reflashed, just updated. If there are no more updates but it has faulty software, you have to bin the ecu...
    Don't remind me!
    16,609
    I'm sure that somewhere there is a person who can re-virginise the ECU. Be nice to know who they are.
    Aug 2012
    campbelltown
    223
    If its a bad ecu maybe a second hand one reprogrammed? Ya reckon its the ecu?
    May 2002
    canberra...
    8,752
    I'd start with connections. Also, find the earth points for the loom and ensure they're good - engine bay and inside the cabin.
    Aug 2012
    campbelltown
    223
    Happen to know where the earths are?
    May 2002
    canberra...
    8,752
    On a Clio, 'fraid not...
    Aug 2012
    campbelltown
    223
    Thanks anyhow. I have somewhere to go next. I'll get the sparky to check it out
    Don't remind me!
    16,609
    Aug 2012
    campbelltown
    223
    The parts specified in that post, what are they and what do they look like?
    Don't remind me!
    16,609
    The underbonnet fuse panel is typical iPad/tablet size, usually under a cover and near the battery.
    Primarily it contains a bunch of smaller size relays that are controlled by the in-cabin electronics, in conjunction with some electronics of its own.
    From this panel, many aspects of the car's operation with heavier current draw are regulated. These include headlights, wipers, drivetrain starting and running controls, and vehicle dynamics. As Shanadoo describes, poor connection inside this part of his C5 was greatly compromising the transmission's ability to behave nicely.
    Aug 2012
    campbelltown
    223
    I had a quick look in the dark and all seen secure except one fuse (dont know what the fuse is for) which was a bit loose so I pushed it in tighter but I can tell the socket the fuse is in is just a tad loose still....
    *shrugs*
    Aug 2012
    campbelltown
    223
    al4/dh0 question-imag0401.jpg
    ok this is the fuse box in the engine bay next to the battery. the fuse that was a little loose it circled in green and the plug that i unplugged and plugged back in for no real reason is circled in red.
    no auto light was recorded this morning on the way to work (50km) where as previously it would come on once or twice... relevant? i dont know....
    Aug 2012
    campbelltown
    223
    btw, anyone know what these fuses are for? feel free to label the photo if you want
    Aug 2012
    campbelltown
    223
    Light on once on way home... For the record.
    Don't remind me!
    16,609
    It's a bit like someone trying to grab your bare arm, but they grab your shirtsleeve instead. That's sort of what can happen when electrical conductivity is poor. The physical looseness or tightness of the fuses, isn't much of an indicator in most cases. Sometimes, the amount of metal touching metal was just inadequate after a few years ageing, and the giveaway has been a maker changing to more durable attributes like gold plated connectors.
    Here's a Pug/Cit one: http://www.ebay.co.uk/itm/280915763944 This is a unit of which type I have personal experience of being faulty in hidden ways. It looks like in the background of your photo there are similar relays in the fusebox, so that is probably the corresponding part of your Clio.
