Dauphine Cable help
Results 1 to 3 of 3
    Fellow Frogger! G4ME's Avatar
    Feb 2003
    804
    Default Dauphine Cable help
    Hi Guys,
    I've come across my first stumbling block. How do I get this cable out. Of course the manual is brilliant in it's advice and says "remove cable" but doesn't say how to get the bloody thing off. While I'm at it I've no idea on the one underneath either.
    I'm dropping the whole rear end out.
    Cheers....Paul
    Attachment 34300
    There is a law against doing more than 100kmh...there's no law on how fast you get to 100kmh!!!
    1000+ Posts Frans's Avatar
    Auckland
    1,487
    Paul,
    Knock the shiny part a few mm back. It has little splines that cuts into the bracket. Then you can pull it back and slide the cable out where the slot in the bracket is.
    Regards
    Frans
    Old enough to know better
    Young enough to do it anyway.
    10,755
    That's right.
    The outer cable housing pushes into the bracket. The housing has a smaller diameter section that slides sideways from the bracket when it is pushed back far enough for the fine "splined" bit to be clear of that bracket. Knock it back and it will be obvious.
    Same for the clutch cable beside it is it not?
    Paul,
    Regards
    Frans
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
