Fuel line for series 1 Mi16 questions
    Fellow Frogger! Valentia's Avatar
    Jan 2011
    380
    Default Fuel line for series 1 Mi16 questions
    Does anyone happen to know the type and lenght of hose needed to run fuel from inside the engine bay to the motor on a series 1 Mi16? As mine has cracked better then a desert and is now dropping fuel on the motor and we all know what that leads to.
    7,487
    Mostly 5/16", however the entry of the fuel injector rail is 3/8". EFI hose naturally, not CARB.
    tweed heads
    1,503
    Default from memory
    thing about a meter will cover it ,thats from the solid pipe ,under the left hand side to the regulater then another bit from there to the fuel rail ,do it asap as high pressure fuel being sprayed on a hot motor will cause an impressive fire and the end to your car ,pugs ,make sure its EFI HOSE
    Jan 2011
    380
    Execlent thanks guys! Is the series 2 Mi16 around the same size as might as well replace both at the same time even though the series 2 seems fine..
