RCZ Transmission issue
Results 1 to 22 of 22
    Jun 2012
    1
    Default RCZ Transmission issue
    Hi Guys.Hoping someone can shed some light on an issue i have.Ive owned an RCZ for the last 6 months and have until now never had a problem.The other morning when i got in the car i put the car in drive and it immediately went to D3 and stayed there.I moved selector to Neutral and park which was ok but once in Drive it went straight to D3 and was surging.I hope this makes sense.Peugeot say they could not find anything wrong.Also the ASB ? light came on.Any ideas would be appreciated.
    Fellow Frogger! Doush_504's Avatar
    Cairo, Egypt
    623
    IIRC anti-pollution fault causes the car to go to "limp" mode.
    Chadi
    1982 504 SR white manual sedan with A/C (257 000 Km)
    2012 308 1.6 VTi Vapor Grey manual H/B (35000 Km)
    1994 405 1.6 white manual sedan (208 000 Km)
    1992 605 SV24 (91 000 Km)
    2005 406 2.0L automatic (Replaced with a 2013 C5)
    1983 505 GR white manual sedan with A/C (170000 Km)
    All since new
    brisbane
    102
    make sure no one pressed the "snow" mode by mistake. I have heard this can do something similar to what you described.
    Fellow Frogger! Valentia's Avatar
    Jan 2011
    380
    No idea on the auto side of RCZ as mine is manual sorry. Will see if the UK mob know anything about it though
    NSW
    4,917
    Is is the AL4 again?
    Cairo, Egypt
    623
    Quote Originally Posted by danielsydney View Post
    Nop, it's the 6 speed auto.
    Chadi
    All since new
    1000+ Posts Capago's Avatar
    Hornsby, NSW
    1,012
    take it to your local dealer and get them to fault read it again. let the issue come and go a few times to make sure its logged good and proper. it will lock into 3rd gear if there is a fault with the gearbox, so it will appear sluggish. AM6 gearboxes are much more reliable than the old AL4 however they still have the occasional issue
    268
    If the fault is intermittent, the dealers will have a hard time trying to diagnose the problem, because fault codes are not always stored after you restart the car.
    If you present the car to them while it's faulty with warning messages flashing and whatnot, then they have a much better chance of obtaining a fault code which provides them something to work with - and don't forget to keep the car running!
    That's computers in cars for ya.
    CitroŽn Tragic UFO's Avatar
    9,732
    The computer systems will also lock the gearbox into limp home mode if there are other electrical problems. Have them check the main fuse box/panel near the battery (assuming it is near the battery in the RCZ).
    Jan 2011
    380
    There is a fuse box in the glovebox. Not sure of under the hood. Will have to check it out
    9,732
    Quote Originally Posted by Valentia View Post
    It's probably a great big thing near the battery full of fusible links and relays.
    lost
    11,055
    Icon6
    G'day,
    I have one of them.
    regards,
    Les W.
    206 GTi 180
    the stealth Pug
    9,732
    Quote Originally Posted by pug206gti View Post
    G'day,
    I have one of them.
    Yeah but what about your car?
    Avisford NSW
    550
    Default Transmission
    Forget the dealers go to John McGraw Automatic trasmissions on Parramatta Rd,Croydon.
    (02)97451055
    He knows more about these transmissions than any dealer/ mechanic will ever learn.
    Robbo
    9,732
    Bet Paris to a paving stone that this problem is electrical.
    Jan 2005
    Melbourne NSW
    813
    Quote Originally Posted by Diesel_vert View Post
    If the tech knows what he is doing he can read between the lines and LISTEN to the customers complain to track the origin of the fault.
    Unfortunately with "computers" in cars these days most mechanics don't know what to do if there is no fault code for the problem described, and if there is a code, the replace what the code is about rather than the cause.
    Eg a dealer had a 1.6 206 with fault code misfire on cyl 4 plus cat converter failed fault. They were going to replace the coil, spark plugs, O2 sensors and the cat until the owner got a second opinion. The actual cause of the faults? There was a chunk missing out of no 4 exhaust valve.
    Oh and here's another thing you may want to know - we have a first year working at work, and we just found out that they don't teach in the syllabus anymore how to strip down and fix engines/gear boxes any more as its all done by "specialists" these days.
    Awesome.
    Current stash
    too many.
    Passed over stash
    lots.
    9,732
    I say this because the symptoms you are describing sound identical to those that some people with C5 Series 3 with the AM6 box have had happen. Replacement of the under-bonnet fuse box removes the problem. Chances are as they are both PSA products there will be similarity of parts.
    Should get a life 2353's Avatar
    Brisvegas
    4,049
    Folks, its a manual. This one is definitely not an auto gearbox fault,
    Save the earth, it's the only planet with chocolate.
    lost
    11,055
    Icon6
    G'day,
    are all the tyres exactly the same? Heard this today. If one of the tyres is a different brand, it could have a different circumference. Only slightly, but enough to trick some of the electronics.
    regards,
    Les W.
    206 GTi 180
    the stealth Pug
    9,732
    Quote Originally Posted by skyline View Post
    Quote Originally Posted by 2353 View Post
    Ah, the OP told us with his description that it is an AUTOMATIC.
    Mar 2012
    PORT MACQUARIE
    2
    Hi I have heard that the RCZ had an issue with the alternator starting to turn backwords, this happened to mine and I had the alternator replaced and all is well now
    happy driving
    s and s
    Hornsby, NSW
    1,012
    All faults are stored in the BSI along with the mileage they occurred, disappeared and how many times its occurred. Will not be logged if there is a fault with another system, such as the BSI itself, it will not log faults because its stuffed.
