Pug 206 GTi 180 Crapped Thrust Bearing
Results 1 to 18 of 18
    Tadpole GerardLePeugeot's Avatar
    Jul 2011
    27
    Default Pug 206 GTi 180 Crapped Thrust Bearing
    Hey guys, my pug recently crapped it's thrust bearing, 2nd time, bought the Panther replacement clutch kit to fit from US, $280 vs $670 for kit from pug wholesaler here in Sydney (OEM part which has failed twice now in 70+k).
    After pulling out battery + assay, noticed there's a nice little puddle of oil sitting on the gearbox, though the direct source isn't easily found on the engine. Don't want to run the engine as the thrust bearing is at least partially seized and I don't want excessive heat passing to the main drive spline.
    I don't believe it's the common head gasket fail, as the gasket on mine was replaced with a quality unit while under warranty.
    Any other known fails I should know about?
    1,376
    Wow two thrust bearing in 70000 km? You must give it a flogging!.... What color is the oil you found? I'd be suspecting something else like leaking PS fliud or spilt oil from an oil change.
    Evan maybe a camshaft seel. ?
    Jul 2011
    27
    The first thrust bearing and clutch was in the hands of the previous owner, which was actually brought on by the (infamous) head gasket seal failing on the rearside of the block, small amounts of oil getting into the clutch mechanism, etc. I understood this to be about 40k, fixed under warranty.
    Oil on the gearbox is dark honey, though oil in the engine is a nice light honey. Oil level hasn't dropped a noticeable amount. Some traces of lighter oil higher up the back passenger side of the block, I'm suspecting a cam seal too or something in the variable workings.
    Jul 2011
    27
    Hey guys, looking for tightening torque for 206 GTi 180 flywheel and clutch housing.
    Thanks!
    Dec 2010
    Central Coast NSW
    32
    Flywheel tightening torque 4.8da.NM
    Clutch housing tighten screws to 2.0 da.NM
    Sep 2003
    North Parramatta
    3,997
    It just so happens I have factory data for this - though it's in Safari webarchive format. Refer to the attachment for bolt sequence. I think Peugeot suggests replacing the flywheel bolts.
    Flywheel:
    1. pre-tightening in the order shown (1 to 8): 2.5 da.Nm
    2. slackening in the order shown: 180
    3. pre-tightening in the order shown: 0.8 da.Nm
    4. tightening in the order shown: 2.5 da.Nm
    5. angular tightening in the order shown: 42 3
    My Haynes says the clutch pressure plate bolts are 15Nm for petrol engines, but Peugeot data I have seems to suggest 20Nm.
    Attached Thumbnails Attached Thumbnails Pug 206 GTi 180 Crapped Thrust Bearing-flywheeltorque.jpg
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    Jul 2011
    27
    Thanks!
    Mar 2011
    Brisbane, QLD
    137
    Okie dokie, so i did an oil change yesterday, could have spilt a little oil down the back not paying attn for a split second, also did the front brake pads and over flowed the reserve, thought id cleaned it all up but now when i put my foot on the clutch it sounds like a samurai fight is taking place in my enginebay, what did i do??????? Can i simply clean something or have ai done damage???
    PUG 206 GTI 180
    AEGEAN BLUE
    OZ RACING ULTRALEGGERAS
    BREMBOS
    ACHILLIES 123S TRACK RUBBER
    AST SPORTLINE I
    AST SOLID TOP MOUNTS
    EMS EXHAUST
    EMS TUNED
    AP CLUTCH
    PHILLIPS HIDS
    GENUINE MORETTES
    IPOD CABLE
    DYNAMAT
    107 fwkW DYNO'D 2012
    Don't remind me!
    16,609
    Does your oil pressure light go out?
    Does the car drive normally?
    Mar 2011
    Brisbane, QLD
    137
    Havnt noticed oil pressure light do anything, drives normally but huge shudder getting it off the line,
    PUG 206 GTI 180
    AEGEAN BLUE
    BREMBOS
    AST SPORTLINE I
    EMS EXHAUST
    EMS TUNED
    AP CLUTCH
    PHILLIPS HIDS
    GENUINE MORETTES
    IPOD CABLE
    DYNAMAT
    Don't remind me!
    16,609
    Probably a small oil spot on the clutch. I'd expect it will fade rapidly.
    Mar 2011
    Brisbane, QLD
    137
    So what about the pedal not returning correctly, the metal on metal screeching ?
    PUG 206 GTI 180
    AEGEAN BLUE
    BREMBOS
    AST SPORTLINE I
    EMS EXHAUST
    EMS TUNED
    AP CLUTCH
    PHILLIPS HIDS
    GENUINE MORETTES
    IPOD CABLE
    DYNAMAT
    Don't remind me!
    16,609
    You didn't describe those details above!
    Check the cable path at the pedal end, then the gearbox end. Could be that it's partly unhooked (not sure of the 206 cable end, but almost possible on some other PSA kit).
    Jul 2004
    803
    The 180 uses a hydraulic clutch in rhd configuration. WRC, noise is present all the time but gets worse on depressing the clutch pedal? Sounds like a failed throw out bearing and or also a failed pressure plate. Shudder is defs a pressure plate problem, time for a new clutch WRC. Not the hardest job but not fun either on a 180.
    2006 Peugeot 206 Xt
    1991 Toyota mx83 grande 1jzgte
    Sep 2003
    North Parramatta
    3,997
    Quote Originally Posted by James504 View Post
    Yes, using fluid from the brake reservoir...
    Simon
    Don't remind me!
    16,609
    I'd temporarily forgotten that! Yes, thrust race has pushed through the pressure plate fingers.
    Jul 2004
    803
    Usually what I've found it will be is the bearing cage has failed and ejected some or all of the ball bearings from the throwout bearing. What you are left with is metal on metal contact. This damages the pressure plate and the input shaft guide. It can go as far as destroying the CAS, balls get stuck in the starter ring gear teeth and come around and smash the sensor open and the vehicle cuts out. Either way you are on borrowed time.
    2006 Peugeot 206 Xt
    Mar 2011
    Brisbane, QLD
    137
    I did mention a samurai fight taking place! Haha. Ok so new clutch kit and possibly a skim on flywheel if not a newy. I want to upgrade clutch to something 20-45% more bite to match power upgrades on car. Has anyone here played with clutch options for the RC ? Cheers M
    PUG 206 GTI 180
    AEGEAN BLUE
    BREMBOS
    AST SPORTLINE I
    EMS EXHAUST
    EMS TUNED
    AP CLUTCH
    PHILLIPS HIDS
    GENUINE MORETTES
    IPOD CABLE
    DYNAMAT
