405 SRDT 97 Air in Fuel line
    May 2011
    brisbane
    22
    Default 405 SRDT 97 Air in Fuel line
    My Car starts after standing over night very badly and there is a lot of blue smoke.I have put a new Battery in it. New Glowplugs. all new O Rings in Fuel filter. I have discovered that when i Prime the system with the the Rubber egg until it is getting hard in the morning the car will start quite easily. During the day withe 2 times Glowpluging there is no issue. Now someone suggested to me to put a electric Fuel Pump near the Tank. It should make the starting much easier. It should also makes the car run better. I have a recondition Bosch Diesel Pump fitted 2 Years ago. What do you think I could do?
    12,266
    Quote Originally Posted by veels View Post
    replace the fuel primer bulb
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    tweed heads
    1,498
    Default second that
    the primer not only pumps, but has a one way valve in it which prevents fuel from running back to the tank if you have to pump it up its, running back PUGS
    May 2011
    brisbane
    22
    Thanks for the Tip i get a new one
    Jan 2006
    North West Tas
    46
    Would love to know how this worked out for you.
    Cheers.
