Coolant For 405 SRDT
Results 1 to 3 of 3
    Apr 2004
    Western Australia
    237
    Default Coolant For 405 SRDT
    Hello can anyone help me by telling me what sort of coolant to put in my 405 SRDT Cheers
    Fellow Frogger! tomb's Avatar
    209
    50/50 glycol and distilled water or the premixed gylcol so long as it is 50% glycol, thats what the 505 SRTD gets
    Mar 2011
    Linton.Victoria.
    1,235
    Hi-Whatever you use make sure you flush the system properly as if they are incompatible thn the 'packman' will chew up the Alloy.
    I have used Tectaloy for many years [10 plus]when I found out that it was significantly superior ,in tests, to G.M.'s 'Special Brew.
    In speaking to a Tectaloy guy he suggested never to mix one bottle of the Tectaloy with another as their may be some change that may make the pair incompatible..
    I would assume that if the batch no. was the same that would override the above.
    You could use Peugeot's coolant should wish.When using a cleaner & flushing I always remove the thermostat so as you do not have to get the engine up to full temp. & then not having to risk any damage while flushing with cold water.
    Pekay.
