Battery tray rust
Results 1 to 8 of 8
    Jul 2003
    222
    Default Battery tray rust
    Leaking battery acid has eaten away paint on battery tray. Some surface corrosion has developed but nothing a wire wheel won't fix. Could someone please specify the exact products I need from Supercheap auto to neutralise the rust and protect into the future? (need to shop online and have delivered - no time to do it any other way).
    1992 205 Si
    Current: shortened diff (4.4), short shifter, group N top mounts, rebuilt engine and box, solid engine mounts, 1.75" exhaust, strut brace, OMP wheel, GTI suspension & subframe front and rear, lowered 30mm front and rear, solid rear bush, Koni yellows, 306 XT front discs and calipers, ADR compliant braided brake lines, 14" rallye wheels, Dunlop Direzza Z1 Star Spec tyres, immobiliser
    Fellow Frogger! rubyalpine's Avatar
    Christchurch, New Zealand
    484
    Hi there,
    Su'cheap over here in N.Z. used to sell 3M Rust Neutraliser, which is an excellent product, but have recently ceased stocking it. Hopefully you can get hold of some over in Aus. I've successfully used Septone engine enamel (from Su'cheap) as a finish coat.
    Cheer, Henry
    1000+ Posts Mike Tippett's Avatar
    Jan 2002
    Vancouver Island, Canada
    1,751
    Best stuff is Zinga, a cold galvanising system. You can paint it.
    1966 Peugeot 404 Coupé Injection post-restoration reassembly underway!
    Register your 404: https://recensement.leclub404.com/submit.php
    Jul 2003
    222
    Thankyou both
    1992 205 Si
    Oct 2011
    Toowoomba
    650
    Default Bicarb soda.
    Quote Originally Posted by Langers View Post
    I usually pull the battery and tray out about every 18 months. wash the whole area with hot water and bi-carbonate of soda (neurtralises acid) two desert spoons in a bucket of hot water. I wire brush, deoxidine and paint with generic rust guard or similar. There are typically a few bubbles and some white poweder in the paint at 18 months.
    1000+ Posts Capago's Avatar
    Hornsby, NSW
    1,012
    if you wire brush it that much you cant see any rust, isnt that good enough? (assuming it hasnt eaten through)
    Oct 2011
    Toowoomba
    650
    Default soda it
    Quote Originally Posted by Capago View Post
    If you mix up a teaspoon of bi carb in a glass and slop it on and it doesn't fizz up, then there is no residual acid.
    Jan 2002
    1,751
    ....or you could paint it with Zinga and it will never rust again, acid or no acid.
