Headlight problems
Results 1 to 9 of 9
    Mar 2012
    Medowie
    5
    Default Headlight problems
    Gurus,
    My daughter's 2006 307 XSe HDi manual is suffering from a slight problem.
    I noticed her R/H low beam headlight wasn't working (high beam worked) As she drove off I also noted the rear R/H tail light wasn't working as well.
    Can anyone shed any light on this at all please. I know stuff all about Peugeots and their electrickery systems.
    Gazza
    Blue Mountains Australia
    84
    First replace the globes and see what happens. The quality of globes varies and you get what you pay for. I went though three generic brand replacement headlight globes in a couple of months on the Scenic. Bought more expensive replacements and have not had one fail since.
    Dec 2002
    Menzies Creek
    2,541
    Occam's Razor - the simplest solution is usually the correct one. Two blown globes would be the most likely scenario.
    If this sounds unlikely to you, consider this: I was doing a routine servicing on a 747-200F which involved, amongst lots of other things, testing every single light globe on the aircraft. When testing the pilot's panel lights, I found that I couldn't get any light at all from the network of 40-odd globes which were supposed to bathe the instruments in light. My first thoughts were that there was something wrong with the wiring, so I headed to the wiring diagrams. Armed with some testing equipment, I headed back to the aircraft... only to find that there was power where it should have been every place I checked. It turned out that every single light globe in the circuit was blown!
    So I spent the rest of the day replacing globes. Which is a pain in the neck on a -200!
    So two globes on a car, even at virtually the same time, is no surprise at all to me.
    I see what you did there!
    Scotty
    Melbourne - Dandenong Ranges
    2014 Peugeot RCZ - 'Remy'
    lost
    11,055
    Icon6
    Quote Originally Posted by Demannu View Post
    G'day,
    probably easier than two globes on a 206
    regards,
    Les W.
    206 GTi 180
    the stealth Pug
    1000+ Posts mr bern's Avatar
    Feb 2003
    Melbourne (or touring)
    1,152
    errrm .... so you just replaced them? Didn't find it at all odd that all 40 had decided to fail simultaneously?
    (and can you post the plane's reg no so we can all avoid it in future?)
    MY15 208GTi
    previously:
    MY10 Sportium HDi6 and 1.6L auto
    MY99 206GTi
    MY96 306XSi auto
    MY02 Clio 1.4L auto
    1ére grenouille:
    MY5? Simca Aronde 90A
    QUICK! MORE BREAD, MORE CIRCUSES!!
    Dec 2002
    Menzies Creek
    2,541
    Quote Originally Posted by mr bern View Post
    Yes, I just replaced them all and tested the system afterwards.
    I'm quite sure that they didn't fail simultaneously, B-checks were carried out at intervals of about 1600 flight hours, so there had been plenty of time for them to fail. Add to that the fact that it was the 'storm' setting on the cockpit lighting with the problem, which is rarely used, and it is completely understandable for such an unservicability to go unnoticed. There was no reason to suspect anything underlying problems.
    Scotty
    May 2004
    wollongong
    40
    Gazza..
    had the same issue with my C4... one blown right headlight and one of the rear lights... when I bought a new front globe there was another funny smaller globe in the packet as well... and that fitted the rear.. so I am guessing that's a common issue with 307/C4 electrickery. The globes I got were Narva H7 12v 55w
    Sep 2003
    North Parramatta
    3,997
    A 200 Freighter? Do yourself a favour - don't step onboard one!
    It's unlikely that you will - unless you are a horse, a box of seafood, a pallet of computers, a car, etc. but the advice is freely given
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    Fellow Frogger! denxm's Avatar
    uki aust
    450
    Default every one is a winner
    my money is on demannu, black caviar has got to to fly to the uk soon
    he has got the right attitude,replace all the bulbs, it maybe the same plane the all
    round champion has to fly on
