306 1.8 Flywheel w/ BE1 trans and be1 clutch kit?
Results 1 to 3 of 3
    Sep 2011
    61
    Default 306 1.8 Flywheel w/ BE1 trans and be1 clutch kit?
    I bought a clutch kit and flywheel for my 89 205 gti.
    Got a 306 1.8 flywheel. Seems the same apart from having timing teeth and I noticed the flywheel is thicker than the one I just pulled off.
    Now I have the gearbox on the floor and not sure whether the combination of using the 306 1.8 fly with the BE1 clutch and trans will be all good.
    Or am I going to have to get a different flywheel?
    I just want to bolt the thing together. Not getting a BE3 trans
    1000+ Posts pug-life's Avatar
    Geelong
    1,226
    Whats wrong with the standard GTi flywheel?
    Just replace the clutch and be done...
    Sep 2011
    61
    Clutch slipping mad.
    Doing the clutch, figured I'd change the flywheel also.
    Which after removing found ring gear teeth chewed out.
