505 battery light weirdness
Results 1 to 3 of 3
    Jan 2012
    Gold Coast
    163
    Default 505 battery light weirdness
    S2 505 GTi: Battery light on with ignition (and everything else)off,it goes off when ignition switch on or acc before engine started, also light is off with apparently normal charging with engine running. Suspect alternator or voltage reg is the root cause...any ideas??
    Regards
    Simon
    Mar 2011
    Kendenup WA
    124
    Yes.
    Start engine. Turn h/lights on with hi beam.
    Connect multi-meter across battery terminals. Should read about
    13.5volts if alternator charging OK - & not fluctuate.
    It is possible that the field transistor that controls the field windings earth circuit is on the blink.
    Pavel
    Aug 2003
    NIMBIN
    33
    check the brushes in the alternator probably well worn. Have had three fail on me with intermittent charge .
    eventually it ceases charging & you will stop by the side of road when battery voltage drops below 11.5 V
    Ron
