Peugeot 206 engine immobiliser?
Results 1 to 7 of 7
    Jerangle
    784
    Default Peugeot 206 engine immobiliser?
    How does the immobiliser work?
    I have bought a Peugeot 206 2006 to repair but can't get it to start,been sitting in a yardforsome time.
    The key looks original with the plip in the key base.
    I will check the spark and the fuel pump but i read the handbook and wondered if the car has been immobilised?
    How do you get around this problem?
    Berridale
    melb
    4,379
    #shouldaboughtahonda
    Dec 2005
    HOBART
    1,265
    Quote Originally Posted by Berridale View Post
    Berridale
    If it's anything like 306/406 there should be a reset button in the engine bay adjacent to the the LHS strut or the fire wall. It'll probably be a black button with a rubber shroud.
    1998 Peugeot 406 D8SV Manual
    1999 Peugeot 406 D8ST Auto
    2002 Peugeot 406 D9SV Manual
    1994 Peugeot 306 XR N3 Hatch
    Over 60 Pugs in my time
    Gerry Mullock
    Fellow Frogger! cme2c's Avatar
    235
    My 206 is causing trouble with an immobiliser fault . The immobiliser is a computer function. The key has a transponder which is a collar around the key barrel (under the plastic cover). These cars HATE flat batteries. You need a scanner to connect to the OBD2 port to discover the problem, amd hopefully clear it. Hope I have given you some clues. Mine was flatbedded to an expert from my usual mechanic, who replaced the split fuel pump, but the thing STILL wouldn't start, and came up with an immobiliser fault.
    Probable cause? I killed the battery by having the hazards on too long while waiting for the tow truck when it first broke down.
    oh, and @purr-geot. The problem with buying a Honda is, you have to drive a Honda!
    206 GTi 2003
    VW Golf 118TSI 2009 ( the wife's)
    Bedford CF 1980
    Valiant VJ Ranger 1974
    "Driving a 206GTi makes you feel like you're 18" Jeremy Clarkson
    1000+ Posts cav91's Avatar
    Romsey, VIC
    2,332
    When we get a wreck come in and it won't start, (providing it has compression) we bleep the doors locked and then unlock. You wouldn't believe how often this works! Also about Honda's, they are as bad as all the rest!
    2017 Renault Koleos auto
    lost
    11,055
    Icon6
    I have bought a Peugeot 206 2006 to repair but can't get it to start,been sitting in a yard for some time.
    Berridale
    G'day,
    is the battery [in the key] ok ?
    regards,
    Les W.
    206 GTi 180
    the stealth Pug
    Jerangle
    784
    Funny,i went to bed last night after reading all the articles and links.
    Thinking the worst .
    Digestion of info during sleep allowed good comprehension of a mountain of info.
    i went to the car applied the reset process to the letter, found the re-set button and the car started!
    However the engine was noisy.
    The truck driver had smashed a hole in the sump during loading!
    Many thanks for the info.
    Berridale
