205GTI Re-wiring question
    1000+ Posts FIVEDOOR's Avatar
    Jun 2011
    Brisbane Qld
    20,554
    Default 205GTI Re-wiring question
    Found almost broken wire (first photo)
    Found broken wire is attached to funny sized male connector (photo 2 and 3)
    Are these connectors still available?
    Hoping to keep things original or close to original.
    Attached Thumbnails Attached Thumbnails 205GTI Re-wiring question-p1090747.jpg   205GTI Re-wiring question-p1090745.jpg   205GTI Re-wiring question-p1090748.jpg
    19,211
    Quote Originally Posted by FIVEDOOR View Post
    http://www.jaydeeautocables.com.au/c..._Catalogue.pdf
    Hang in there it will take a while to load depending on your connection speed.
    9,011
    I didn't manage to find that size, it's just a tad smaller than comercially available spades around here. Just solder the wire and heatshrik it, preferably with glue heatshrink. As a bonus, this way you keep the wire number.
    ACHTUNG ALLES LOOKENPEEPERS
    Jun 2011
    Brisbane Qld
    20,554
    Thanks Robmac.
    I did find a what appears to be the same connector on the Jaydee catalogue(see photo). The image of the connector appears to be the same and item H2571 is the correct width, but it takes 1 mm cable. Not sure if will stretch over 2 mm cable. Might be worth checking out.
    I received helpful PM which indicated listed an item as Solenoid Blade 6524 V5 A=5 (width) B=1 (I assume this the thickness) 2mm (the cable thickness) which is what I am after. I did some searches last night on the "Solenoid Blade 6524 V5" that it got a mention on some 205GTI Drivers forum discussions, I followed some of those leads, before I ran out of petrol. Still looking.
    Thanks schlitzaugen, that's always an option.
    Thank you all.
    I have to go and finish assembling a small garden shed. Wife happy with shed as it will get the bikes out of sightt, I am happy with more shelf space. I have complete engine, spare block and a gearbox on the garage floor looking for temporary home. Need more space around the car to have room to work on it.
    As an aside picked up two 185 x 850 galvanized sheds at Stratco on sale for $189.00 each. I know they are small, but space is at premium and I have a small niche where they can fit.
    Attached Thumbnails Attached Thumbnails 205GTI Re-wiring question-blade-connector-2.jpg
