505 GTI intermittent cut out
Results 1 to 13 of 13
    Near Mullumbimby, NSW
    347
    Default 505 GTI intermittent cut out
    The 505 motor has taken to occasionally cutting out. Just stops dead, but will start up again right away and run normally. Has happened 3 times over perhaps a month. Dirty injectors have been suggested but fuel has been regularly Lucas treated and fuel filter renewed not long ago and she is fed BP 98 always.
    Any other ideas?
    Goonengerry 505
    Oct 2003
    canberra
    856
    I had that happen several times in 92 gti, after stuffing around with pumps filters etc
    replaced the tachyometric relay under the steering column, instant solution
    You can fit a normal relay if you know what you are doing apparently
    good luck
    anywhere
    2,003
    In less complex ageing cars - poor connections/wire breakdown in the HT circuits can cause difficult to locate cut-outs.
    Fellow Frogger! julian b's Avatar
    Aug 2011
    hawthorn melbourne
    482
    i had a similar problem once with an mgb . it was a dodgy ignition switch , i only had to depress the clutch and start it again without stopping .
    1000+ Posts Beano's Avatar
    3,142
    Isn't the tachymetric relay for starting only ?
    Just as a matter of interest to some, once I could only start occasionally in a '92 505 and I took the cover off that relay. Looking at the soldered connections with a magnifying glass, I spotted a tiny fracture around one. A quick touch with the soldering iron fixed the problem.
    Oct 2003
    canberra
    856
    T relay controls the fuel pump, .
    3,142
    Well, it's easy to check anyway.
    If you take off the shroud under the steering column and look under the dash, it is a relay, slightly bigger than most relays, which has a lot of wires going to it. No other relays do. Take it out, take off cover, and look closely under good light at the soldered connections on one side. Take your time and look for a tiny circular crack which will be all around at least one bit of solder.
    Armidale
    2,452
    Do you have any symptoms of fuel starvation? My Citroen Xantia was cutting out when I tried to accelerate - it had clear signs of fuel starvation. Like your 505, it would start again immediately, but you couldn't clutch start it. Fixing the fuel issue seems to have fixed the cutting out, so I assume that the engine management system was cutting the spark when it detected a lean mixture.
    See following thread for more detail:
    http://www.aussiefrogs.com/forum/sho...05#post1066205
    Alec
    Feb 2002
    Tamworth NSW
    496
    Icon7
    Quote Originally Posted by thomevans View Post
    Any other ideas?
    Unless you have a coil issue, or electrical leads / terminals supplying the coil, the tachymetric relay is most often the cause of this problem.
    Other possibilities include the HP fuel pump (rather than the lift pump). You might also consider the "over-run relay", which, if your model is a Series 2 GTI, cuts power to the fuel pump on deceleration (accelerator not pressed) when RPM is above 1200. This is located on the firewall near the brake booster.
    K
    347
    Thanks for all the replies fellas.
    SWMBO has now admitted that the motor in fact doesn't cut out completely, car just gradually slows down with no response when pressing the accelerator. It does always start and run normally again on turning ignition off and re-starting, so fuel starvation from filter or injectors seems unlikely. It hasn't happened again since I posted.
    Will try and find time to check the tachymetric and over-run relays this weekend, or maybe simply replace them.
    Does the late 505 actually have a lift pump in the fuel tank? Mr Haynes does not mention one.
    Goonengerry 505
    1000+ Posts okalford's Avatar
    Sep 2004
    10,956
    It could be worth checking the hoses to the air flow meter if you have not already. One tiny crack can be hard to spot but cause them to play up.
    KA
    Oct 2003
    canberra
    856
    Default 505
    yes there is an in tank pump access thru the large plastic plug in floor under the carpet lhs about 400mm from bumper, retained in tank by a ring you have to unscrew. it is all a bit tight for access but can be extracted ( remember no smoking while doing this )
    I have been there and found it was the Tachy relay after all
    when you are examining the tachy relay if it pongs of burnt plastic / bakelite it is suspect
    I guess you have replaced the can filter near the main pump under rear lhs seat ? they can block up
    5,312
    Icon10
    Don't suppose the intermittent cutting out coincides with the latest "must-have" shoes / clothes appearing in the shops?
    If she comes home and tells you it wouldn't restart for half an hour, you can almost guarantee Jimmy Choo are on special.
    Mike.
    Started out with nothing, still got most of it left.
