306 N5 advice please
Results 1 to 9 of 9
    Northern NSW
    1,075
    Default 306 N5 advice please
    I'm going to check out a cheap 306 hatch N5 for the boy on Thursday.
    Is there any specific stuff I should look for?
    My usual thing is to just look everywhere I can, under and in the engine bay, give the suspension a shake, check for leaks and give it a drive.
    Look for accident repair/rust and check fluids etc. If it's clean and no funny noises and goes and handles and stops and they provide a roadworthy is there much else I should be aware of?
    Apparently there is a service history too.
    Thanks.
    Melbourne Australia
    1,382
    Good luck to you I have 2 x N5s for my son and daughter. We all love them, one of Peugeots best models.
    As far as checking basically the same for any car and includes the tests you have stated. I would add driving at a 45 degree angle up a driveway to listen for creaks or thumps to test droplinks, wishbone bushes, strut top bushes etc.
    Most important is service history re: cambelt changes, waterpump, regular oil & filter changes etc as these cars will last for ages if well maintained.
    Fellow Frogger! BradlehGordz's Avatar
    Sep 2011
    398
    Check to see if the cooling fans work if you can (turn a/c on whilst running) and make sure power window and mirrors work as well as a/c working. They're common problems.
    Other than that, I can't think of anything else off the top of my head (:
    Andrew pretty much covered it (:
    P-Plater
    Obsession for le Peugeot!
    Current:
    '98 306GTi6 + Bianca white+ Sun roof.
    Previous:
    '99 306Style
    I live for the 6!
    Sep 2003
    North Parramatta
    3,997
    The #1 thing on my 306 list would be to check that the heater works.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    Sep 2011
    398
    Quote Originally Posted by SLC206 View Post
    I thought I miss something! Haha
    On that topic SLC, if the heater doesn't work, does that mean the heater piping is just looped through the bulk head and by passes the matrix?
    P-Plater
    Current:
    Previous:
    '99 306Style
    I live for the 6!
    Northern NSW
    1,075
    If the heater isn't working and the pipes are bypassed and all, are parts available to fix the matrix?
    Would they be horribly expensive ? I realize it would be a nasty job to change but how nasty? If it's like the 406 I wouldn't want to do it. I attempted to remove the heater from my 406 wreck but never quite got there and in the process broke bits of the glovebox and stuff. I imagine it would be fairly similar? Like a complete dash dismantle?
    Sep 2003
    North Parramatta
    3,997
    Quote Originally Posted by BradlehGordz View Post
    Most likely - it's a very cheap fix to a leaking matrix that way, but means the heater no longer works.
    Quote Originally Posted by luthier View Post
    I don't think there is any issue with getting parts - it's just either an expensive job to pay someone to do or a time consuming job for you to do. Unlike the 405 it's a full dash out job. I'm not familiar with the 406 requirements.
    There was a thread on here some time ago (with pictures) dealing with the 306 matrix change, but it may have vanished in the great crash. This thread has some helpful links.
    Simon
    Jerangle
    784
    Simon,
    if you find the thread on the heater replacement please post the link?
    Wet carpet on the passenger side foot-well.
    I thought it was the rain......no bloody way that lucky!
    Fellow Frogger! paulrb's Avatar
    Dec 2004
    Geelong
    214
    Icon14
    On top of what has already been posted... check:
    The rear window wiper/washer; that is works...
    All door electrics.... mainly for the window switches...
    The petrol filler neck was replace under a recall.
    That the indicator switch in the stalk doesn't 'click'
    That the fuel filter is still nesting nicely where it is supposed to be... they are plastic and when replace in some services might be put back poorly (cable ties or even nothing holding them at all) causing the joins to the fuel lines to take stresses and vibration and of course they fail and leak.
    That the heater blower motor is relatively silent...
    That the pivots for the rear parcel shelf are intact.
    Current Beasts:
    '89 405 Mi16
    '98 406 ST TD Wagon
    '90 405 MI16
    '67 Morris Mini
    Recent Pugs..
    '94 306 XR
    '01 306 XT
    '98 306 XT
