Question for the prv brain trust
    Dec 2011
    Athens, Greece
    298
    Default Question for the prv brain trust
    We plan to replace the piston rings in a PRV and I am wondering if the crankshaft bearings must also be replaced. We replaced the bearings 2,200 km ago so they should be in good shape, but do they get compromised during the piston ring change? I am not too concerned about the cost of the bearings, it's the 1,000 km break-in period that is the real PITA. The piston rings we will be using require fewer than 50 km for break-in.
    12,256
    unless you suspect the bearings to have suffered oil starvation or other damage i can't see a reason to change them
    1 x '98 306 GTi6
    Dec 2011
    Athens, Greece
    298
    Quote Originally Posted by pugrambo View Post
    Thanks, Rambo. Just to be sure I am asking the question correctly as works cranks are hard to come by:
    I am fairly certain that the bearings are fine, oil temp and pressure were always spot on and the sump is gated.
    The piston rings are worn and will be replaced, this requires that we remove the conrods (hence the bearings) from the crankshaft.
    My mechanic is concerned that if the bearings are reinstalled the tolerances will not be very good, but he has no experience rebuilding PRV engines.
    So just to confirm: is it safe to install the same crankshaft bearings after taking them off to replace the piston rings?
    Fellow Frogger! stew's Avatar
    Apr 2011
    brisbane
    493
    Default Yes
    If they have not been damaged, they will be fine. Just don't get them mixed up and keep them in the same conrod. If you are nervous use some plastigauge to check clearance.
    Dec 2011
    Athens, Greece
    298
    Thank you both, I will make sure everything is marked properly and we will re-use the bearings. It's a relief, avoiding a 1,000 km break-in; such wasteful wear on all the other rare parts (works gearbox and LSD, triple Webers etc), not to mention the pain of driving a rally car at 3,000 rpm for 20 hours.
